Silver sludge in oil
66corsaguy
Unread post by 66corsaguy » Tue Aug 08, 2017 11:39 am
Hello all should I be concerned with silver sludge in oil? I'm redoing some stuff to figure out what previous owner did and did not do. So far it's got viton everywhere so that's a great sign but I am seeing this silver stuff and want to make sure it's ok
1966 Corsa
Re: Silver sludge in oil
Unread post by azdave » Tue Aug 08, 2017 2:52 pm
Could be excess assembly lube? Was it a fresh rebuild? Might be no issue at all if that's the case.
Is it magnetic? Is it a fine powder type of material or can you feel some grit when rubbed between your fingers?
65 Corsa 140 4-speed
66 Corsa 455 Toro V8
65 Monza 455 Toro V8
65 Monza 4DR EJ20T w/5-speed
Unread post by terribleted » Tue Aug 08, 2017 2:55 pm
Is it slimy? could be lead deposits from back in the days of leaded gas that never got cleaned out. If it is that not a big deal. I would guess that if it is not magnetic (not steel) and not crazy amounts it is likely of little concern. I have seen large globs of slimy silvery lead deposits in oil pans before.
skipvair
Unread post by skipvair » Tue Aug 08, 2017 4:29 pm
I used to use silver anti seize lube on all bolts
66corsaguy
Unread post by 66corsaguy » Wed Aug 09, 2017 2:00 pm
The motor was gone thru by previous owner and rings replaced and all that. It is slimy. Not metallic like metal but like a lubricant
Guess I shouldn't be too worried
Thanks!!
66corsaguy
Unread post by 66corsaguy » Wed Aug 23, 2017 3:00 pm
skipvair wrote:I used to use silver anti seize lube on all bolts
I think that is the answer. I bought anti seize for aluminum and it is aluminum in color. Why there is so much of it I have no idea but I think that's the winning answer. Maybe from when the rocker bolts were replaced who knows.
Nothing to worry about I hope.
Unread post by terribleted » Wed Aug 23, 2017 3:18 pm
Here is a photo of silver sludge in an oil pan. In this case it was around 1/2" thick and covered with oily goo. It is lead deposits in this engine. I am guessing this oil pan has not been off for a very very long time. Most of the bolts in and around the engine appear to be untouched since new:)
Danny Joe
Unread post by Danny Joe » Wed Aug 23, 2017 5:49 pm
Could it be zinc from the oil?
'64 Spyder Convertible
