Valve Questions
jmikulec
Valve Questions
Unread post by jmikulec » Thu Aug 03, 2017 2:58 pm
If I have a 64 turbo 150 head and it's the 164 ci engine, can I put the the bigger 140 valves on there without a lot of trouble?
thewolfe
Re: Valve Questions
Unread post by thewolfe » Thu Aug 03, 2017 3:12 pm
No. You can fit a 140 exhaust valve in if the head is machined for the larger 140 seats. The 140 intake valves are too large to fit in a small valve head because they are positioned out toward the cylinder wall more than a 140 head. They can be turned to a smaller diameter to fit though, along with machining the head to fit an appropriately sized seat. Tom Knoblauch does this conversion and I have a set of 95 hp heads he did this to in my car. Top notch work but not cheap.
Nate Wolfe
65 corsa 180
Re: Valve Questions
Unread post by bbodie52 » Thu Aug 03, 2017 3:38 pm
All valve specifications can be found on page 8 - POWER TRAINS (Adobe Reader Page 42 of 79) in the attached 1965 Chevrolet Corvair GM Heritage Center Specs.
The 95, 110, 180 hp overall valve head diameter is INTAKE: 1.335-1.345, EXHAUST: 1.235-1.245.
The 140 hp overall valve head diameter is INTAKE: 1.715-1.725, EXHAUST: 1.355-1.365.
:chevy:
The attachment 1965 Chevrolet Corvair GM Heritage Center Specs.pdf is no longer available
(2.01 MiB) Downloaded 8 times
jmikulec
Re: Valve Questions
Unread post by jmikulec » Thu Aug 03, 2017 4:08 pm
Ok if I were just going to change this motor to a 110 with two rochesters would I get the 110 valves and would they work with this turbo head? What other modifications do I need?
Re: Valve Questions
Unread post by terribleted » Thu Aug 03, 2017 4:52 pm
If you want make your turbo engine into a 110HP engine, you need 2 110Hp heads, 2 carbs, proper throttle rods from the side of the trans thru the linkage to the carbs, 2 carb fuel line set, a 110HP distributor, and likely a different camshaft. The turbo heads are not the same as 110 heads. They are turbo only in design (the difference is in the shape of the combustion chambers mostly). You can put carbs, linkages on your turbo heads, change the distributor to one with vacuum advance (non turbo),and operate the engine that way. I am not sure what the HP result would be, nor am I sure how drivable it would be ( I am betting reasonably ok). Perhaps someone that has operated one like that will chime in.
toytron
Re: Valve Questions
Unread post by toytron » Thu Aug 10, 2017 4:14 pm
I bought a 65 corsa that someone took the turbo setup off and just put two carbs on. It runs fine but it doesn't run as good as it could with all the proper changes as Ted had mentioned. I plan on swapping it out after I get the body work done because I have a 65 engine with the turbo I picked up last year.
jmikulec
Re: Valve Questions
Unread post by jmikulec » Sun Aug 13, 2017 3:37 pm
Is there such a thing as tulip valves for a corvair? Also, are clarks tufftrided valves any good? Just need good strong valve for a street use 110 hp engine.
