FC transmission mount
Gearfinger
Unread post by Gearfinger » Thu Jul 06, 2017 10:38 am
Hi all. New guy, first post. My Greenbrier has a 4spd trans supported (poorly) by a mount intended for an automatic trans. As hung, the left bank is an inch or so below where it should be. This also gets the rear wheel alignment off. I'm hoping to find info as to the actual differences in mounting bolt locations and measurement. Have called some common suppliers trying to find the proper crossmember, so far no luck.
Any help deeply appreciated. My location is mid-Michigan...
caraholic4life
Re: FC transmission mount
Unread post by caraholic4life » Thu Jul 06, 2017 1:17 pm
Looking in the Clarks catalog I found the following:
http://www.corvair.com/user-cgi/catalog ... ge=USED-18
Part number CU261: USED FT TRANS CROSSMEMBER 61-62 FC 4SPD $0.00 (Page Used-18) Out of Stock.
Part number CU264: USED FT TRANS CROSSMEMBER 63-65 FC 4SPD $60.00 (Page Used-18)
If you are in need of a 1963-1965 F.C. 4 speed version, you may just be fortunate enough that they may still have one available. :my02:
Gearfinger
Unread post by Gearfinger » Fri Jul 07, 2017 5:38 am
Sadly, my rig has the proper trans. Have also checked with Corvair Ranch and some others. Thanks for your consideration.
dave t
Unread post by dave t » Sat Jul 15, 2017 9:23 am
Give Jeff at california corvair a call. He knows his stuff and most likely has the part in stock.
Gearfinger
Unread post by Gearfinger » Sun Jul 16, 2017 6:06 am
No luck with CC for me. The on line ordering system would allow only shipping to the billing address, which is 150 miles away. Phone calls went without answer. ???
dave t
Unread post by dave t » Tue Jul 18, 2017 8:35 pm
I recommend calling again. Cal corvair is closed Sunday & monday
racndave
Unread post by racndave » Wed Jul 19, 2017 8:44 am
Gearfinger wrote:Hi all. New guy, first post. My Greenbrier has a 4spd trans supported (poorly) by a mount intended for an automatic trans. As hung, the left bank is an inch or so below where it should be. This also gets the rear wheel alignment off. I'm hoping to find info as to the actual differences in mounting bolt locations and measurement. Have called some common suppliers trying to find the proper crossmember, so far no luck.
I have a complete FC crossmember from a 1961 rampside 4 spd. If interested.
racndave
Unread post by racndave » Wed Jul 19, 2017 12:03 pm
