Fuel pressure 12psi
Fuel pressure 12psi
My fuel pressure is running at 12 would like to get around 3 or 4 I heard you can cut the fuel pump spring any feedback would be great Corvair Forum mobile app
Sent from my SM-N900W8 using Re: Fuel pressure 12psi
Yes you can try cutting the spring but I have found some of the newer pumps will not come down much. What I have done is swap in a spring from an old OEM AC Delco pump.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
It's an ac delco pump I just don't know how much to cut and the spring is cone shaped may be a little from top and bottom
If you have two fuel pumps you could simply try transplanting the spring from the old fuel pump you dissected into the active pump (without cutting it). The different spring may be all that is needed to reduce the fuel pressure down to the desired level.
I will give it try getting good at taking things apart numerous times and putting it back together
The "new" AC Delco pumps are NOT the same as the original AC Delco pumps. They are just like the Airtex or Spectra pumps.
When I said AC Delco, I meant one of the OEM original AC Delco or similar.
1966 Corsa turbo
I wonder if there is a way to fatigue the new spring in one of the center coils?
Success so my original psi was actually 7 don't no why I put 12 anyways I cut two coils of the top that got me down 5 than I cut a quarter more iam at 3 1/2 now which is great because my venturi is not dribbling anymore still need to get these carbs rebuilt
Probably just need a float adjustment. So now when your driving at highway speed is the pump going to keep up with demand?
I hope so there is a lot of fuel coming out the line I was told that newer fuel could increase the pressure and I was running at 7 psi now iam in between 3 and 4 venturi is not dribbling float is set to spec carbs are a mess getting sent out for a rebuild
