Fuel pressure 12psi
Coolair
Fuel pressure 12psi
Post by Coolair »
My fuel pressure is running at 12 would like to get around 3 or 4 I heard you can cut the fuel pump spring any feedback would be great
Sent from my SM-N900W8 using Corvair Forum mobile app
Coolair
Re: Fuel pressure 12psi
Post by Coolair »
This is an old fuel pump I dissected
notched
Post by notched »
Yes you can try cutting the spring but I have found some of the newer pumps will not come down much. What I have done is swap in a spring from an old OEM AC Delco pump.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Coolair
Post by Coolair »
It's an ac delco pump I just don't know how much to cut and the spring is cone shaped may be a little from top and bottom
:think: If you have two fuel pumps you could simply try transplanting the spring from the old fuel pump you dissected into the active pump (without cutting it). The different spring may be all that is needed to reduce the fuel pressure down to the desired level.
Coolair
Post by Coolair »
I will give it try getting good at taking things apart numerous times and putting it back together
notched
Post by notched »
The "new" AC Delco pumps are NOT the same as the original AC Delco pumps. They are just like the Airtex or Spectra pumps.
When I said AC Delco, I meant one of the OEM original AC Delco or similar.
1966 Corsa turbo
toytron
Post by toytron »
I wonder if there is a way to fatigue the new spring in one of the center coils?
Ed Stevenson
Coolair
Post by Coolair »
How do you tell if it's oem original ac delco
Coolair
Post by Coolair »
Success so my original psi was actually 7 don't no why I put 12 anyways I cut two coils of the top that got me down 5 than I cut a quarter more iam at 3 1/2 now which is great because my venturi is not dribbling anymore still need to get these carbs rebuilt
64powerglide
Post by 64powerglide »
Probably just need a float adjustment. So now when your driving at highway speed is the pump going to keep up with demand?
Coolair
Post by Coolair »
I hope so there is a lot of fuel coming out the line I was told that newer fuel could increase the pressure and I was running at 7 psi now iam in between 3 and 4 venturi is not dribbling float is set to spec carbs are a mess getting sent out for a rebuild
