Pilot Bushing
Pilot Bushing
Spent some quality time trying to remove one from my 1968 140 motor. Speaking to a Chevy friend he said that his buddy packed the area behind the bushing with grease then used a shaft the same size as the inside of the bushing to push the grease (I guess hitting the shaft with a mallet) and create a hydraulic effect to remove the bushing.
Jeff
Jeff
1965 140 Corsa
1965 Corsa Convertible
1966 Crown V8 383 435hp
1986 Buick GN V6 600hp
Re: Pilot Bushing
Hah I've done that, but I used bread instead of grease. I saw a number of discussions on the net about using bread to remove a pilot bushing. I decided to give it a try - what could it hurt ???
My first problem was I didn't have a rod which fit the inside of the bushing. I tried a 1/2" rod, but that didn't work - it just squished the bread out. So, I went to Home Depot and bought a 4" x 5/8" bolt. I used my bench grinder to grind 1/16" off of the threads about 1" from the end. A 9/16" rod is a prefect fit and the head of the bolt is a perfect hammer impact spot. Then I put masking tape on it to mark the max depth that I needed to go into the bushing. I packed the bushing with plain white bread and used the bolt to drive it in. Some more bread - more packing - and what do you know ??? The bushing popped right out. Took about 5 minutes...
I guess grease would work as well but bread makes a better story when you tell your friends how you removed the bushing.
Alec
Alec
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
Dahlonega, GA
Re: Pilot Bushing
I have an old junk input shaft that I use. I pack it with grease and it pops right out. My buddy Dave uses bread and that works well too.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
- caraholic4life
Re: Pilot Bushing
Many many years ago I invested in a Pilot Bearing/Bushing removal tool because I was tired of doing things the hard way.
I have not used it in over 20 years now but will have it when I need it again.
Many folks sold a version of this back then, and still do today.
Prior Kelmark Owner
Prior Kelmark Owner
Re: Pilot Bushing
The old grease or bread trick has been around for some time - BEWARE to use gloves and a full face mask. A few have reported injuries when hydraulic pressure shot the grease/bread out past the shaft or bearing.
I bought an internal bearing puller form HF. It's a slide puller, very easy to use, very effective. Just use a coupon for 20% off this one https://www.harborfreight.com/slide-ham ... 62601.html
Or this one https://www.harborfreight.com/3-jaw-pil ... -4876.html
Re: Pilot Bushing
I was able to use a slide hammer attached to a 1/4 inch bolt. Got the head of the bolt behind the bushing and it slowly came out.
Jeff
Jeff
1965 140 Corsa
Re: Pilot Bushing
A 5/8" tap works very well, just screw it in until it locks and then use it to turn out the bushing.
'64 Spyder Convertible
