Stud replacing
Stud replacing
Just put on my new style 5 bmw rims and my rear studs are too short. Can I just bang out the old studs with a big hammer do have to take the hub off was also thinking of picking up some one inch adapters. Would the adapters solve my problems? Any help would be great.
Re: Stud replacing
I had the same issue when I out Iroc rims on my '66. Rear studs would only engage 3-4 threads on the lug nut which wasn't enough to make me feel safe. You can drive out the old ones pretty easily with a big hammer, I threaded a lug nut on to keep the threads from getting mashed up, 2-3 whacks will pop them out. I used a Dorman replacement stud and slid em in, about an hour to do both sides and have the wheels back on.
Case R.
1966 Monza 140 coupe
Western Champlain Valley, Vermont
Re: Stud replacing
I believe the stock size is 7/16-20 .472 knurl 1-1/2 length having some trouble finding the right part
Re: Stud replacing
I would need minimum 3/8 longer or 1/2 would be ideal
Re: Stud replacing
I used Dorman 610-157
Case R.
Re: Stud replacing
Found them listed and available on Amazon.com (what isn't???)
https://www.amazon.com/s/ref=nb_sb_noss ... an+610-157
Also...
https://www.summitracing.com/parts/rnb- ... Alo68P8HAQ
Brand: Dorman
Manufacturer's Part Number:610-157
Part Type:Wheel Studs
Product Line:Dorman Wheel Studs
Summit Racing Part Number:RNB-610-157
UPC: 019495608578
Wheel Stud Style: Press-in
Wheel Stud Thread Size: 7/16-20 in. RH
Underhead Length (in): 2.125 in.
Knurl Diameter (in.): 0.487 in.
Quick-Start Nose: No
Quantity: Sold as a set of 10.
Notes: Be sure to check your existing knurl diameter, length, and thread size for proper fit.
Re: Stud replacing
Just placed my order there on there way hope I can get to drive my vair by the end of summer once again thanks for the help
