Ride height LM
skipvair
Ride height LM
Post by skipvair »
Want to level up mu nose down LM and would like someone to post profile pics of theirs with new Clark HD and Standard springs.
Frank Metasavage
66 Corsa 140 4 speed Stock
Re: Ride height LM
Covered here a few times.
Most just replace the old tired rear springs for a level stance (when new these cars were all nose high) and leave the old front springs in.
If you want a nose down look then folks cut a coil off the front spring.
The HD springs lower the car about an inch all the way around vs. stock springs.
On heavier rear cars (convertible and four doors with the heavy fold down rear seat) use the rear "Convertible" springs as they have a higher spring rate, without lowering the car like the HD springs.
Depends on the look/ride you want.
skipvair
Re: Ride height LM
Post by skipvair »
skipvair wrote:Want to level up mu nose down LM and would like someone to post profile pics of theirs with new Clark HD and Standard springs.
Frank Metasavage
skipvair
Re: Ride height LM
Post by skipvair »
Thats why i want to see pics. Someone cut the front springs on this in a previous life. I like a little low, I think. Want to see pics with HD springs all around.
Frank Metasavage
drewvair
Re: Ride height LM
Post by drewvair »
The google machine is failing me. I've found the ride height numbers for EMs but not LMs. Can someone help a guy out? My car is a bit of a mystery to me as I bought it at auction. Thanks!
1965 Corsa Turbo
Portland, OR
