What is this spring for? Passenger side.
- GasDaddy140
Hi! I can't figure out where this spring goes. Can you help me?
Thank you.
Thank you.
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
Re: What is this spring for? Passenger side.
More information and a picture that is zoomed out a little.
Ed Stevenson
Ed Stevenson
This spring is not stock. Some PO's idea for increased throttle return pressure I bet. Can not tell by photo exactly where this is but I'm betting spring was connected to a secondary carb. I would remove it, as only 1 return spring should be ok on the throttle linkages if they are set up properly.
- GasDaddy140
Re: Better Picture-What is this spring for? Passenger side.
Here is a better picture of location, passenger side sheet metal. Almost looks factory. Thanks for your help!
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
It is NOT anything that GM put there. There are several short grounding straps around the perimeter sheet metal that connect to the engine compartment perimeter frame, but no spring.
- GasDaddy140
OK Thanks everyone! The spring goes.
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
- davemotohead
Alan, I bet that was the return spring for your secondary carb, Remember the other one had a tab on it for the spring?
- GasDaddy140
Hey Dave, that little notch is on the other side and I'm utilizing that little spring you gave me, just softened it up.
Since this Corsa and motor had a missing carb set when I found it...who knows.
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
