63 corvair powerglide selector cable removal
Datsolow
Post by Datsolow »
Hi all,
Can anyone advise on how to remove this? do I remove from inside the car or can it be disconnected from the powerglide unit?
Many thanks Paul
cnicol
Re: 63 corvair powerglide selector cable removal
Post by cnicol »
The cable can be disconnected at either end.
Dash end: Unclip tiny little e-clip at end of cable and use super-short (modified) 5/8" wrench to unscrew the retaining nut.
Trans end: Disconnect retaining strap on body, remove cable retaining bolt (usually 7/16", sometime 3/8"), disconnect throttle rods from trans TV lever, pull out cable.
Note: cable housing is super brittle these days and any crack you create will leak badly when the car is parked for a few days. If you want to ensure the cable's safety, remove the tunnel cover and unclip the cable inside so it can make a big "S" when you push the cable back. Also, support the trans and remove the trans support bracket so you don't have to muscle the cable through the little oval slot in the bracket.
64powerglide
Post by 64powerglide »
Depends on what you are doing? If you are pulling the engine or just replacing the cable??
Datsolow
Post by Datsolow »
I'm pulling the lump & box , which is out now , now to get the heads off😜
