64 turbo fuel gauge not working
snowmaker
Unread post by snowmaker » Thu May 18, 2017 9:16 am
Installed new tank and Gage checked function of Gage before installed worked fine then installed and now does not move off E and tank is full. Checked ground wire as that is all I can think it might be any help greatly appreciated.
Re: 64 turbo fuel gauge not working
Unread post by terribleted » Thu May 18, 2017 11:21 am
make sure both wires are connected to the sending unit (I am sure you have already, but double check good connections anyway). Next drain the fuel and remove the sending unit from the tank and find out what is wrong with it. You can operate the sending unit out of the tank and it will operate the gauge (if it is wired anyway). You say the gauge worked before tank install so tis most likely that some installation error or new issue with the function of the sending unit is at fault. There are checkout steps for the sending unit and gauge in the Shop manual if the gauge does not function when manually operating the sending unit. Hopefully something is simply stuck. (make sure the sending unit float is not full of fuel as well a leaking float will make gauge read empty all the time as it will not float)
snowmaker
Unread post by snowmaker » Sat May 20, 2017 6:02 pm
Thanks for the response. I was hoping on avoiding the draining the fuel tank end of this problem . Most likely I got something out of wack when I put sending unit in I know that I had put the new tank in and then installed the sending unit into the tank & I had checked the sending unit before I installed it in the tank. Oh well at least I can enjoy driving the gas out of the tank first so I don't have to much fuel left to drain. Thanks again
Unread post by terribleted » Sat May 20, 2017 6:30 pm
You can do a portion of the shop manual resistance and continuity checks for the fuel gauge with the sender in the car. Try those first.
snowmaker
Unread post by snowmaker » Sat May 20, 2017 6:58 pm
Thanks I will try that first.
Who is online
Users browsing this forum: No registered users and 4 guests
