Tach repair - sources
rnd5553
Unread post by rnd5553 » Sun May 14, 2017 9:04 am
Looking for a repair shop (source) that could fix a defective, non working factory (Corsa) tach, anyone have any sources/experiences?
Re: Tach repair - sources
Unread post by 66vairguy » Sun May 14, 2017 1:05 pm
SEARCH here and at other forum - Topic comes up often. Myself and others have commented a few times here.
I've repaired some for friends, but I will NOT do anymore - just too time consuming to calibrate them. A few others that did them seem to have quit also. The meter adjustment is tedious and one slip and you destroy the unit. If the meter armature has failed then there are no new parts. The electronics is easy to fix and adjust the gain. Getting the meter to read accurately and linear can take many hours of tedious work.
BTW - The term "repair" can mean different things. Just getting the needle to move is one thing - getting an accurate reading is another.
64powerglide
Unread post by 64powerglide » Sun May 14, 2017 1:56 pm
http://www.bobsspeedometer.com/1/120/tachometers.asp
Never used then but have heard nothing but good work is what they do.
63Spyderd
Unread post by 63Spyderd » Thu May 18, 2017 11:44 am
The Corvair Ranch repairs and calibrates Corvair tachs. They have a good selection of spare parts including the correct replacement germanium transistor, should it be needed.
