Stock oil pressure at idle ?
acarlson
Post by acarlson »
What is it using the stock oil pump when engine is idling (between 600 & 900 RPM) ?
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
cnicol
Re: Stock oil pressure at idle ?
Post by cnicol »
5-10 PSI hot would be pretty typical. 10 PSI per 1000 RPM, regulated to 35 PSI maximum
Since you are rebuilding your engine I'll add that my experience with a rebuilt when priming the oil system (something you should do) with room temperature 10W30 motor oil will give 35PSI by about 1,000 RPM (500 distributor RPM) with a dummy shaft and electric drill.
When you select a oil pump gasket thickness, make sure you plastigauge BOTH gear sides. Sometimes the plate will be worn on just one gear side due to a minor difference between the housing machined plane and gear shaft axis. If one gear has less clearance to the plate than the other - rotate the plate 180 degrees and plastigauge again - usually that will even out the difference.
Sometimes during a rebuild folks will consider a high volume oil pump - IMHO it is NOT needed for an engine with stock bearing clearances and just wastes energy and puts more tension on the distributor/oil pump shaft and gears.
acarlson
Post by acarlson »
Perfect - thanks for the info. I have an electric fuel pump and I'm replacing the safety switch. I just want to make sure the new switch doesn't trigger at a pressure lower then my idle pressure.
As far as my oil pump goes - I already have the high volume pump installed. A previous owner did that. I know I have to plastigauge the gears and I've already talked to Clarks about getting an assortment of gaskets so I can make sure I end up with the correct installed clearance. I had Clarks send me the original installation instructions for it. In any case, that's good info about uneven gear wear on the cover plate. I'll have to check that - thanks.
Alec Carlson
Dahlonega, GA
