Hello, and hmm...
My 1965 140 distributor seems to bottom out with a gap to the housing like a hard stop. What's wrong? Seems to turn well. Any ideas out there in Corvair land?
I've ordered a universal Chevy dist clamp, didn't find one in my boxes.
Thank You!
Getting closer to lighting it up atop my greasy work table.
Distributor Fitment Gap?
- GasDaddy140
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
Re: Distributor Fitment Gap?
The distributor shaft has not engaged the oil pump drive. Using a remote starter button, crank the engine a little, the shaft will drop in place.
- GasDaddy140
Thanks Jerry, I cranked engine around counter clockwise with a wrench while wiggling the rotor and nothing happened. I'll look at it closer tomorrow.
Alan
Alan
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
- GasDaddy140
Re: In Now! Distributor Fitment Gap?
Wow Jerry, I literally just went outside and pushed it in with my finger! Thanks again!
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
If you look at the illustration below, you can see the distributor shaft engaged with the oil pump gearset near the bottom of the engine. The bottom tip of the distributor has a tang that must engage with the slot in the drive gear. Without proper engagement, the distributor drive gear would sit too high and would not be properly dngaged with the drive gear on the crankshaft. Also, you would have no oil pressure without the distributor shaft turning the oil pump gearset.
If you were to remove the distributor and look down the distributor mount opening on the engine, you can see the slotted oil pump drive shaft at the bottom. A long flat-blade screwdriver can be used to turn the gearset to position the slot so that the tang at the end of the distributor will engage as you slide the distributor into place.
The distributor hold-down hardware looks like this, with a nut used to secure the clamp assembly...
- GasDaddy140
Thank You, Brad!
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
