cost to repair corvair plug hole
Re: cost to repair corvair plug hole
If you are re-using a piston check to see if the tight spot in the grove is at the side with the oil slot. Severe detonation will crush the piston, typically at the areas were the oil slot is. You can mic the grove to see if part of it is collapsed. If so, then I would not use that piston.
dick2256
Post by dick2256 »
the binding spot is around 4:30 or 5 o'clock
I will go buy a thin file so I can file it a little and see if it loosens up
