trans will leak out about a quart of fluid if it sits 3-4 days if driven daily doesn't leak at all and can't see where its leaking from any ideas
pg trans
- wheels2108
pg trans
Daniel
Hendersonville TN
corvair powered rail buggy
Hendersonville TN
Re: pg trans
Solution involves heavy cleaning of the engine, trans and differential. Put the vehicle up on jack stands high enough you can slide under on a creeper.
Clean and clean and clean again until there is no residual fluid anywhere.
Let it sit for a few days, with some white paper under the trans and differential area. The paper will give indications of where to look. Then with a good light, use the creeper to crawl under and spot the source of the leak.
Seems like a fun project. (have done it several times over the years)
