Steering box
dmt98239
Steering box
Post by dmt98239 »
Steering box is weeping - my question is buy a "new" one or replace seals. Thanks in advance.
Dave Thompson '64 Monza Vert
Dave Thompson
1964 Corvair Monza Convertible
Coupeville, WA
http://northcascadescorvairs.org/
lostboy
Steering box
Post by lostboy »
Mine craps grease mix out of the bottom. I just keep it filled. There's no play in it otherwise. It's your call. If there's no play maybe you could just clean it all and reseal it.
I see the zerk fitting is that to add more grease? Mine doesn't have that, and I fill it with the recommended mix of gear oil and grease.
-Steve
acarlson
Re: Steering box
Post by acarlson »
I just added new gear oil to my steering box. I used this:
You can get it from: http://www.restorationstuff.com
It is part # LUB009.
It will cost you - their shipping is expensive but it seems like good stuff and the claim is it controls leaking. I haven't had it in there long enough to know if that is true or not.
Alec
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
dmt98239
Re: RE: Steering box
Post by dmt98239 »
lostboy wrote:Mine craps grease mix out of the bottom. I just keep it filled. There's no play in it otherwise. It's your call. If there's no play maybe you could just clean it all and reseal it.
Thanks. Not sure about the zerk fitting - came with the car....along with badly fixed floor panels covered with a whole lot of bondo.[emoji36]
Sent from my SM-T350 using Tapatalk
Dave Thompson
Coupeville, WA
dmt98239
Re: RE: Re: Steering box
Post by dmt98239 »
acarlson wrote:I just added new gear oil to my steering box. I used this:
Alec
Thanks - I will look into this.
Dave Thompson
Coupeville, WA
lostboy
Re: Steering box
Post by lostboy »
Bondo on/in the floor? lol that's awesome.
-Steve
