Stained driveway
eriiczilla
Stained driveway
Post by eriiczilla »
Hey everyone!
So i have a 1960 700 with a power glide and it's leaking (circled in yelow on picture) transmission fluid from what I believe is part of the throttle linkage right above the transmission pan
Can anyone teach me how to stop this leak??
Thanks! :wave:
eriiczilla
Re: Stained driveway
Okay reading around I have found that it is actually the transmission manual valve cable
Sent from my SM-N920V using Corvair Forum mobile app
Replace cable
Not uncommon. Google search and you'll find fixes folks do.
It is by design that transmission fluid occupies the inner cable housing as far forward as where the cable curves up into the passenger compartment near the gas pedal. Because of this, a tear or crack in the outer plastic jacket can lead to a possible leak anywhere along the whole cable. The leak will be worse when the car sits for a long time as fluid up inside the transmission and torque converter slowly drains back after many days and this raises the fluid level well above the cable exit point.
Some have been able to repair the outer cable cover using Rescue Tape self-fusing silicone tape. If you think this will work for you it is a lot easier than replacing the cable but sometimes the damage is too great. If you try this method I very strongly urge you to use only Rescue Tape brand and not a knock-off version. The knock-off brands are not resistant to transmission fluid. It is hard to get the area clean before the tape application. I jacked up the car on the left to tip all fluid to the right. I flushed it well with lots of cleaner and made sure the area around it was oil-free so that as I wrapped the tape around it was not contaminated. I added multiple layers with some decent stretching so that the tape applied good pressure all around.
eriiczilla
azdave wrote: Thu Feb 16, 2017 11:31 am It is by design that transmission fluid occupies the inner cable housing as far forward as where the cable curves up into the passenger compartment near the gas pedal. Because of this, a tear or crack in the outer plastic jacket can lead to a possible leak anywhere along the whole cable. The leak will be worse when the car sits for a long time as fluid up inside the transmission and torque converter slowly drains back after many days and this raises the fluid level well above the cable exit point.
thank you azdave this is exactly what i was looking for. ill post updates when i can. :tu:
I have seen all kinds of things wrapped around and coated onto this area to "fix" leaks. I have never seen a "fix" that lasted a long time. Perhaps you will have better luck than what I have seen.
terribleted wrote: Thu Feb 16, 2017 5:52 pmI have never seen a "fix" that lasted a long time.
The repair on my 66 Monza was still dry when I sold it a few years later. The repair on my wife's 65 Monza is still good after nearly 5 years of use. Others on CorvairCenter report good results after I posted some info there in 2010.
http://corvaircenter.com/phorum/read.ph ... msg-324615
WIll it last forever? Don't know. It depends on how well the area is cleaned and how carefully it is applied by the user. I'm happy with my 5-year leak-free fix for under $10 when the alternative is a full cable replacement job. Last thing I want to do is put in a new PG cable.
https://www.amazon.com/Rescue-Tape-Self ... B00AZOK55G
The repro cables are not all that hot either at least the ones I have installed. They do not leak but I have had them stretch and make adjustment issues. I will have to try this particular tape on one. I doubt I have seen this particular product used before. If I have maybe the prep was insufficient. Certainly worth a try...the worst that can happen is it will leak.
toytron
Post by toytron »
We use self fusing tape in the electrical trade for watertight connections. The key is clean and stretch. You need to get a good stretch on it. Go longer than the damage and give it a 50% overlap. This stuff works great when applied properly. It is a bear to remove when it has been on for many years but you won't need to remove if you end up replacing the cable at a later date.
eriiczilla
Is it recommended I use anything else along side the rescue tape?
