Turn/ High beam diffuser lenses.
County98
Post by County98 »
Starting on my Guage cluster today, and on disassembly, I noticed I'm missing one turn signal lense and the other is broken. Also, high beam lense pretty bad.
What's the fix for these please?Image
Sent from my SAMSUNG-SM-G870A using Corvair Forum mobile app
Cheers!
-Shayne
Lawton, OK
'66 Corsa work in progress
viewtopic.php?f=52&t=8079
County98
Re: Turn/ High beam diffuser lenses.
Post by County98 »
Also, on cleaning the clear Guage lenses, how scared do I have to be about wiping off the white lettering on the inside?
Cheers!
-Shayne
Lawton, OK
Post by Jerry Whitt »
Had a big problem with the rotating mileage indicators. Those seemed to have loose ink very very easily. Good luck
County98
Post by County98 »
Yup, I hear you. Middle 2 rows of my trip odometer flaked off. Literally never even touched them. Just handling the body of the speedo and they fell off. Arg.
Cheers!
-Shayne
Lawton, OK
cwhunt
Post by cwhunt »
Looking at your past posts it looks as though you have a late model.?. Clark has some replacement turn signal lenses, but they are green. Part number C8142Image
Also check out NOS-51. Maybe part numbers CX3514 and Cx3520.
Sent from my SAMSUNG-SM-N920A using Corvair Forum mobile app
Christopher Hunt
San Diego, CA
'63 Monza Spyder 150HP Turbo
County98
Post by County98 »
Sweet. Thanks for checking it out. After thinking about it last night, I went to Staples and picked up some plastic, frosted look 3 ring binder dividers. Different colors, so will probably go with dark green and blue for high beams. It's worth a shot anyway. If it's goofy, I can always order from Clark's now that I know.
Cheers!
-Shayne
Lawton, OK
