Buy a good Arduino book, or books. There are thermalcouple to Arduino chips with cold junction compensation (must use this type), but most are NOT ground isolated. You must use a thermalcouple that is NOT grounded to the shield cover. That gets tricky as many are lower temperature (insulation). I did look at using a floating ground interface, but it just adds more complexity (and signal noise) so I went with a non-grounded thermalcouple. The Arduino doesn't like "car" power (11.5 ro 15VDC) although it will work, but the onboard volatage regulator can run HOT above about 10 VDC (not good for the board). I use a DC to DC micro power supply to convert to 7VDC to the Arduino power input. That eliminates any "electrical" noise glitches. DC to DC units don't generate much heat, unlike the old analog regulators.
KEEP IN MIND MOST OF THESE CHIPS and BOARDS ARE MADE OUTSIDE THE U.S.A. so the prices WILL be going UP!!!!! While there is very little "labor" involved in making chips and boards, companies in the U.S.A. have never been interested low volume manufacturing. Fortunately companies in other countries are.
The high volume advanced chip manufacturing goes off shore since Taiwan can make high quality advanced chips for less than ANYBODY. Just amazing. That said with China threatening to take over Taiwan that may all change. Yes the Binden folks got Taiwan chip companies to build plants in the U.S.A, BUT according to the business news it is NOT going well. The level of engineering and build quality by U.S.A. contractors is inferior and has set the plant building back by YEARS with build budgets going over estimates and no doubt what will be produced WILL cost more!!!
