Bench Wrenching
scooperman
Re: Bench Wrenching
Post by scooperman »
one of the guys I crewed for would let us have the shop radio on a rock channel during teardowns, but when the car was going back together he would only allow country music. Said it was much better for concentrating on your task. Weird guy but a good driver.
Re: Bench Wrenching
joelsplace wrote: Fri May 03, 2024 6:47 am You get 90% good advice here and about 95% bad on Facebook. I feel sorry for the newbies there. I don't see how they can sort through it.
I don't do facebook, but a buddy does and he could not bleed an 80's Camaro dual master cylinder after watching all the facebook information, that it turned out was incorrect. The presenters put on convincing explanations, but all WRONG.
I finally found the GM technical article (there's a mystery valve you have to push, then install a pin ----- really complicated and you have to follow a proper order). We got the master cylinder and system properly bleed.
I'm still amazed by all the "convincing", but totally incorrect presentations on facebook.
Dennis66
Re: Bench Wrenching
Post by Dennis66 »
"It's on the internet, it MUST be true". NOT. Why I try to steer the facebook people here.
Speaking of - last night there was a posting of a '65 Corsa Turbo convertible WITH AIR CONDITIONING (maybe added, but appeared to be GM components, Frigidaire compressor, underdash evaporator. Guy said the condenser was under the front. Car has been in a garage locally for 26 years and just recently seen for the first time. Local club president (which I haven't gotten involved with yet) was approached to buy it. Dennis
Re: Bench Wrenching
No turbo ever had factory A/C and '65 140s didn't either.
erco
Re: Bench Wrenching
Post by erco »
That's about right. Everyone on FB chimes in with "helpful" suggestions and in many cases no one corrects bad info.
Maybe it's just too polite over there. :tu: :tu: :tu:
jimbrandberg
Re: Bench Wrenching
Post by jimbrandberg »
I like when I offer advice to the best of my knowledge and someone corrects my misconception or adds something I don't know. I'm largely self taught through trial and error but try to learn all I can. Mostly why I'm here.
CorvairRepair.com
Dennis66
Re: Bench Wrenching
Post by Dennis66 »
We had a situation on the Isuzu forum a few years back where a member had installed a rebuilt, but couldn't get it to run right. Everybody offered (often good) troubleshooting advice. Finally the moderators asked everyone but a very experienced member to stand down. It still took a while, but the problem finally broke down to forgotten O-rings on the injectors causing a vacuum leak. sometimes the extra eyes can be a drawback. Dennis
Re: Bench Wrenching
The best arguments are the ones I lose. That means I learned something.
erco
Re: Bench Wrenching
Post by erco »
joelsplace wrote: Mon May 27, 2024 7:39 pm The best arguments are the ones I lose. That means I learned something.
