What Model Edelbrock aircleaner for 140hp?
Would anyone using a 14 inch Edelbrock aircleaner on a 140 hp engine please supply which model # you have used. Any issues you might have encountered would also be helpful. Trying to decide whether to go this route or go with 4 small aircleaners. Your opinions highly valued, thank you Duke
- American Mel
Re: What Model Edelbrock aircleaner for 140hp?
Are you desiring something that "Looks Cool", or are you looking to improve performance?jmcasaleiz@gmail.com wrote: ↑Tue May 21, 2024 4:35 pm Would anyone using a 14 inch Edelbrock aircleaner on a 140 hp engine please supply which model # you have used. Any issues you might have encountered would also be helpful. Trying to decide whether to go this route or go with 4 small aircleaners. Your opinions highly valued, thank you Duke
The stock air-cleaner is better then those four little ones Clarks sells.
They are fairly restrictive with those little chrome hoods.
For cheap improved performance, I have seen a lot of 140 owners simply flip the lid upside down when driving the car.
When they show the car, they flip the lid back over to the correct orientation.
I don't know the answer but my initial thought is that the base of our air cleaner housing is so small compared to something that sits on a carburetor. Oftentimes the air cleaner itself is good but the adapter is hokey. Just a thought.
Also provision for PCV in the air cleaner as a place for vapors to go under low vacuum conditions is a good thing.
CorvairRepair.com
CorvairRepair.com
CorvairRepair.com
CorvairRepair.com
I believe that the hole for are air cleaners are the same for 2 barrel and probably 1 barrels also so there should be some options out there. Of course the tops are the same no matter what the base hole size is.
- Frank DuVal
95s, 110s, 140s, and Quadrajets on 455 Buicks... Oh, I was just listing the cars I turned the lid over on....
I like the sound of intake air flowing...
And I like lots of filter surface area.
Hey look, blue background!
