66 Monza Project
MrMonza
66 Monza Project
Post by MrMonza »
The Current condition Of my 2dr 1966 Corvair Monza Coupe # 15,018 Built in Willow Run and the beginning of The Restoration.
91blaze
Re: 66 Monza Project
Post by 91blaze »
Looks like you have a project on your hands, good luck. If you need any advice, help, pictures, etc. just let me know as I also have a '66 Monza.
County98
Post by County98 »
Looks like the condition mine is in pretty much. Seems a little overwhelming, but I'm just doing one little thing at a time. Good luck!
Cheers!
-Shayne
Lawton, OK
'66 Corsa work in progress
viewtopic.php?f=52&t=8079
MrMonza
Post by MrMonza »
91blaze wrote:Looks like you have a project on your hands, good luck. If you need any advice, help, pictures, etc. just let me know as I also have a '66 Monza.
Thanks i'm sure i will have a few q's about the motor. This has not ran in some time. Thinking of rebuilding it.
County98 wrote:Looks like the condition mine is in pretty much. Seems a little overwhelming, but I'm just doing one little thing at a time. Good luck!
Overwhelming? Na ... More excitement. There really isn't a lot to them when you compare to newer cars ( 80's to now). Good luck on yours as well!!
MrMonza
Post by MrMonza »
Moved the Monza today and was stung :angry: by a wasp on the left middle finger knuckle :eek: . Hand still swollen but i won the battle :assault: with wasp spray :rafman: ! Popped the trunk to find 3 spares and the hub caps, took out the front lights and some trim. Also found out that the floor below the back seat is all but gone :sad5: . Oddly i checked the oil and tranny fluids and they were perfect like it was recently done. Which it hasn't. That is a heavy car!!
MrMonza
Post by MrMonza »
Got the tail lights out and trim off ( i know it's still on in the pic) and a can of wasp spray that i keep in the car for when working on it :rafman:
Also tore out the interior to assess the damaged spots. :eek:
Back floor board
Front drivers side
Under back seat
MrMonza
Post by MrMonza »
Shots of the engine after dismantling the shroud i guess.
Right side a mouse had stuffed with cotton from the seats. I found his skeleton as well :eek:
MrMonza
Post by MrMonza »
Finally have the monza in a barn to work on it. front and back windows are out, pulled the carbs off to rebuild, and started sanding it. Now doing 2 days a week. What did i get myself into... :helpsos: Edit: Also found out that the drums were redone and the tranny rebuilt SCORE!!!
64powerglide
Post by 64powerglide »
You have lots of work ahead!!!!! :eek: Save some money, use windex on the Wasps. It kills them fast, works great on Flies too but don't kill the Bee's we need them. Good luck on your project, looks like about $5,000 & you'll be on the road. :banghead:
MrMonza
Post by MrMonza »
Got the Monza off the ground and started sanding a little.... progress is slow but still enjoying it all!
BIGTWIN
Post by BIGTWIN »
Like eating an Elephant, 1 bite at a time. Hang in there.
1961 Monza
MrMonza
Post by MrMonza »
Little more Sanding done....found where there was bondo....they had it way too thick...and way too much!!
County98
Post by County98 »
Looks good! Long way to go for both of us, but fun just to mess around with it.
Cheers!
-Shayne
Lawton, OK
MrMonza
Post by MrMonza »
It has been a while since i posted and have not been out to work on the monza, but might give a thought into swapping the body over to an S-10 frame and putting a 4.3 in it. Does anyone know what specific year S10 frame to use (if there is one) ? Also anyone have a thread on it?
