65 Corsa Convertible project
- tdsherman325
Re: 65 Corsa Convertible project
What are you using for the soundproofing?
Hey TD,
I used the roofing material that is used in the valleys. It is peal and stick, comes in rolls and NO it does not smell like tar!
It took 5 rolls to do the entire floor and top well. I think that the material cost around 14.95 per roll at Lowes.
I will post the results after a road test... Whenever that will be!
Bob W
68 Monza coupe
68 Monza coupe
U.Seal. It's what I used as well.
- Am-Iron
Scott, what was your impression of it? It has been suggested to me by John Miller. He and Theresa purchased a Corsa coupe from me and used it in there. I did not really ask how it improved the interior noise/heat.
Scott, where did you get the Useal? and how much was it?
I am happy with it, it made my car much more quiet. It works/looks just like Dynamat.
I think I paid around 16.00 a roll at Home Depot.
Got back to the project... Family issues !
Bob W
68 Monza coupe
68 Monza coupe
- Corvair.crazy
Thanks for the updates. Are you still on track to get it on the road this summer?
Jon
CORSA member
1962 Spyder convert
1961 Rampside
CORSA member
1962 Spyder convert
1961 Rampside
Of Course, that is my goal. I removed the front brakes and will replace the front hoses today.
The shoes don't look like they have ever stopped the car. I will clean everything and reassemble today. THe mastercylinder is toast so I will either go with the duel set up or rebuild the old MC
Bob W
68 Monza coupe
68 Monza coupe
- Gregory_Miller
I want to deaden the engine noise in the passenger compartment of my Corsa... I wasn't looking forward to the price of DynaMat® I'll have to check out this U.Seal, we have both Lowe's and Homie Depot here in Eugene.
Bob, I'd try a hot air gun for getting the undercoating off, get a cheap one at Harbor Freight.
EDIT: I can't find any reference to U.seal in Lowe's or Home Depot. Any help would be appreciated.
- Am-Iron
Gregory, It is in the roofing department. It is a valley sealer. Someone there should be able to point you in the right direction. You do not need to cover the whole panel usually about 30-40% gives nearly the same results. I just learned that and thought I would share! rfw66 you ar doing a great job! It is making me want to get out there more and finish mine up!
- Gregory_Miller
The valley sealer has the foil backing?
EDIT: Can't find it in the Home Depot roofing department online, meh
- Am-Iron
Hop in that super cool new car! I would be dying for a reason to fire it up! Let me know if you find out about 95 hp heads too, if Dave didn't jump on them. I need some for my turbo engine build.
- Gregory_Miller
I have to make sure they are 95s. I'll check numbers when I get home in a couple of hours.
I still have a roll left so I took a picture of it for you.Gregory_Miller wrote:The valley sealer has the foil backing?
