66 Monza
Holyroller
66 Monza
Post by Holyroller »
Work in progress but almost done . Now to finish the other two
60 700 coupe
61 Lakewood
66 Monza
Re: 66 Monza
Sharp!!!
Re: 66 Monza
Looks amazing!
Bruins_Fan
Re: 66 Monza
Post by Bruins_Fan »
Welcome to CF! Great looking Vair!
61SuperMonza
Re: 66 Monza
Post by 61SuperMonza »
That's a good looking Monza. Really like the kidney bean wheels with full polish. Great stance.
NORM
First corvair in 1985
Have owned 4 corvairs since
65 Corsa coupe 180 turbo
66 Monza coupe 110 PG
66 Monza coupe 140 PG
Anchorage,AK
Holyroller
Re: 66 Monza
Thanks sniper efi works well but took some adjusting running to get right
60 700 coupe
61 Lakewood
66 Monza
61SuperMonza
Re: 66 Monza
That Sniper efi setup sounds interesting. I'm sure many forum members would like details on the install and setup. I see they have a kit for forced induction as well. That could be sweet on a turbo motor. Have you noticed improvements as it "learns" the more you drive it?
Norm
Anchorage,AK
Holyroller
Re: 66 Monza
Yes gets better as you drive. Lots of easy adjustments via the hand held computer which I mounted in center arm rest . Drove up and down mountain with and it worked seamless . I’ll do a pros and cons and how to on the forum under another thread
60 700 coupe
61 Lakewood
66 Monza
doug6423
Re: 66 Monza
Post by doug6423 »
NICE! Image
65 Monza
Cincinnati, OH
Re: 66 Monza
Beautiful Monza! :tu: :not worthy: :thumbsupwink: :runwoohoo:
I do have one technical recommendation, though. The Positive Crankcase Ventilation (PCV) connections appear to be incorrect. The large tube is properly connected to the air cleaner, but the smaller side tube (fixed orifice) must be connected to the intake manifold to provide the necessary manifold vacuum to scavenge the crankcase piston blowby fumes from the crankcase and run them through the engine intake to be reburned and discarded. Without this the PCV system likely is less-effective than the early-design road draft tube used in 1960-1962 Corvairs, and excessive oil contamination will likely accumulate in your beautiful engine.
Holyroller
Re: 66 Monza
Thanks for the input I’ll try it
60 700 coupe
61 Lakewood
66 Monza
Hank_jackson
Re: 66 Monza
Post by Hank_jackson »
good afternoon all
good looking install what flavor sniper did you use?
I used the 2gc model on my 110
how did you handle the temp sensor?
Hank
Re: 66 Monza
Brad is correct on the PCV. It is no longer a PCV at all the way it is now.
monza66coupe
Re: 66 Monza
Post by monza66coupe »
That is a great looking package! I never thought the bumble bee would look good but that is sharp... have any problems on damp/foggy days?
Holyroller
Re: 66 Monza
Live in the the desert in southern Cali so never damp or foggy but I have driven through mountains no problems
60 700 coupe
61 Lakewood
66 Monza
Holyroller
Re: 66 Monza
The sniper 2300. I made a temp sensor out of brass fittings with small amount of oil inside. I drilled out and tapped the choke hole at number 5 cylinder. Wrapped in shrink wrap to insulate and it runs at 185degress so it thinks it’s in water cooled engine.
60 700 coupe
61 Lakewood
66 Monza
