My '65 Monza Convertible project
CarMel
Post by CarMel »
This how it was sitting when I first saw it. It had survived a barn fire, with a lot of upper scorching, but still ran ok. The owner was offering it free, with a title to a good home, so I jumped at the chance.Image
Re: My '65 Monza Convertible project
WOW..Holy Smokes (literally! hahhaa)...But it runs, that's more than I can say for my "as found" project.
CarMel
Post by CarMel »
Right, extremely rough, but work with me here and you'll see things slowly get better. The first thing I did was add some fresh wheels and tires, just so it would be a bit easier to look at. You remember the '85 Buick T-Type wheels? They look pretty good on an LM and blend well with the design of the cooling fan, too.Image
CarMel
Post by CarMel »
It rolled so much easier with the new tires, that I was able to get it inside and up on the jackstands. I hadn't owned a Corvair since '77, so it was a real trip back in time, as I removed parts and got the body stripped down. It was originally built in Los Angeles, so it's probably less rusted than it could have been, located here in Wisconsin.
CarMel
Post by CarMel »
By this point, I had decided that so much would have to be bought for the car to be 'as original', that I came at this from a different angle and decided to make it a project car, with an alternate body style. So the cutting began...
WoW! Impressive! You've done a ton of work. This is going to be a very nice build, thanks for keeping us up to date!
Phil Dally
Post by Phil Dally »
Wow indeed..lots of work.
Are you doing a tilt nose?
Paso Robles CA
CORSA Member
Plus 5 Chapters
Sidewinder SCTA
Unsafe at any Landspeed
LA Angels fan since 1978
So Cal Gas Co Since 1974
Retired After 40 Year Career
CarMel
Post by CarMel »
I shortened the platform, removing 15" and butting the sills back together, since there will be frame tubes above and below, which will bear the main loads. At 93", it's basically the same wheelbase as a Porsche 911. The floor was rusty and I needed to sit lower anyway, so it was cut away.
I got down to some foam body plug forming, using the Monza SS as my basic inspiration, but upsizing it to fit the width of the production Corvair chassis. The front and rear fiberglass clips will be removable, to make the chassis more easily serviced.
Here, the body is pretty well shaped and I've moved up to 17" wheels and tires. The windshield plug will provide both the full-height and cut-down plexiglass panels. The 'roll bar' section will be a separate, bonded part, just like on the original car.
CarMel
Post by CarMel »
You know the SS will never be available at any price we could afford!
The size thing worked out really well. In order to fit the LM track and stay in proportion, the entire body was sized 6% larger than the original, and that oversize gave me a wheelbase of 93", which will give the car better overall balance. As a bonus, the interior now fits full size adults, too!
Mel
b-vair
Post by b-vair »
Another WOW!!!
On a side note did you take any close up shots of the front rockers, door/windshield posts? I've got a lot of work to do to my '66 vert.
4carbcorvair
Post by 4carbcorvair »
Wholy crap!!! :o
Awsome!!!
Dirigo Corvair group.
SpyderMan
Post by SpyderMan »
Mel, I love the progress pictures. Do you think you might be up for a visit in person some time? It is going to be a long winter here in good old WI. :lol:
Sam Russell
1962 Monza Wagon
1964 Monza Spyder
mlevair
Post by mlevair »
Simply Amazing!!!
Michael LeVeque
Michael LeVeque
LeVair Performance & Restoration
Anderson,IN
765-617-9307
Chrissy
Post by Chrissy »
Wow, and I thought my corvair looked pretty bad and rusted when I looked at it. But I'm sure it is now a beau! :D
Wozer! :eek: The wheels are sharp. As is the body you have planned.
Keep up the great work!
Trip
Post by Trip »
I saw this car in person, painted and beautiful in Detroit at the DACC homecoming... it is beautifully done.. the bodywork is straighter than a brand new Corvette!
Now that I see how he went about building it, I've got all kinds of ideas of my own.
Incidentally, from what I saw the whole body was done in carbon fiber!!!
Ray "Trip" Rodriguez III
Gouldsboro, PA
66 Corsa 140 coupe
64 Monza Convertible
