Ride Height
Re: Ride Height
I have 205/60 - 15 tires on mine which is about the same diameter as the stock size tires. When I rebuilt the front end discovered that both front springs were broken one complete coil turn. So squared up the ends and reinstalled.
All coil springs are original so they are saggy.
Steve
Bakersfield,CA
1969 monza coupe
110, 4speed
Bakersfield,CA
1969 monza coupe
110, 4speed
Re: Ride Height
OK. Thanks for all the input and advice. Y’all seem to be saying to forget the ride height and fix the exhaust.....so I will
Gary Roberson
Re: Ride Height
plrgpr wrote:OK. Thanks for all the input and advice. Y’all seem to be saying to forget the ride height and fix the exhaust.....so I will[emoji106]
Frank Metasavage
66 Corsa 140 4 speed Stock
Re: Ride Height
Nobody seemed to mention that if it has HD springs, they will lower it too. I am with everyone else here. Looks great at that height. Fix the mufflers. BTW.... clarks sells 2 different sets of 140 mufflers. Coming
From someone
Who gave away the cheaper set, the more expensive set with the prebent correct tubes is worth the difference in fit, appearance, and they don’t drone like the less
Expensive ones.
From someone
Expensive ones.
Frank Metasavage
Re: Ride Height
Frank. I was told by the guy who did a partial restoration of my car in 1980 that the car does have HD springs (F41). He said it also had am/fm stereo multiplex when he sold it......long gone now. Don’t suppose you know where there are any reasonably priced units even if they’re inop?
Gary Roberson
- GasDaddy140
Re: Ride Height
Your car looks awesome. The ride height is nice, I especially admire the slightly nose proud attitude of the late models!
And as many have chimed in your exhaust...are truly demented. Sickeningly so. :)
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
Re: Ride Height
I am noticing the same thing with the front end of my 66 Monza Sport Sedan. Coil spacers didn't help. I'm running 185x75 R14 tires. The Chevy shop manual says new springs are the only way to restore ride height, but now it's too cold to do any work outside. I happen to have a set of LM heavy duty springs but they will make the ride too hard, so I may just wait till "spring" to install new "springs " (pun intended )...
Bill Hershkowitz
66 Monza Sport Sedan 110 PG Factory A/C
Bill Hershkowitz
- 64CorvairMonza
Re: Ride Height
I am going for a set of air shocks after I change out my springs so I can set my ride level perfect and take a load off my springs at the same time. Poor springs shouldn't bear the load all alone.
Re: Ride Height
Here are some Corvair-related comments...
Delco Pleasur-lift air shocks for LM?
http://corvaircenter.com/phorum/read.ph ... 662,965856
- 64CorvairMonza
Re: Ride Height
I have absolutely nothing against using air shocks and have done so since I was 16 years old. They should NEVER be a substitute for bad worn out springs!!! Replace your springs and front shocks and add these to the rear and you'll be glad you did. Yeh, you can't beat OEM!! Your springs will thank you and you may get about an 1"lift on the front as well. Remember, all the weight is in the back on a Corvair. Lift that back and the front will follow to a certain extent.
Last edited by 64CorvairMonza on Fri Dec 27, 2019 5:45 pm, edited 1 time in total.
- 64CorvairMonza
Re: Ride Height
I noticed you are in NC! Have you clicked on their LINK >> NC Mountain Corvairs << over at that site lately? Do it and come back an answer this question......Do you belong to that club?
bbodie52 wrote: ↑Wed Dec 04, 2019 7:25 am Here are some Corvair-related comments...
Re: Ride Height
VAIRS IN THE VALLEY — October
1 h 38 min (84.1 mi) via US-64 E
https://vairsinthevalley.wordpress.com/
https://www.vairsinthevalley.com/
They are based in the Asheville area, about 100 miles north of my location. Atlanta is about 100 miles south https://www.corvair.org/chapters/chapter303/, and Chattanooga TN is about 100 miles west https://choochoocorvairs.webs.com/, so I am in the middle of nowhere for regular Corvair-related meetings. About the closest Corvair get-together is the annual Corvair Springfest in Helen, Georgia...We also host an annual Vairs in the Valley car show in October. The event is held in Maggie Valley and celebrates any and all Corvairs. Corvair lovers are welcome!
SPRINGFEST — April 2020
31 min (20.7 mi) via GA-17 S/GA-75 S
https://corvairspringfest.com/ April 24 & 25, 2020
Choo Choo Corvair Classic in Chattanooga TN
Choo Choo Corvair Classic in Chattanooga TN — Mid-August
2 h 13 min (113.2 mi) via US-64 W
I will make a serious effort to leave my Hermitage and attend all three Corvair gatherings in 2020.
- 64CorvairMonza
Re: Ride Height
Bahahahahahahahahahahahaha, there's always one in the group.
