1965 Monza Coupe Thread
Tim_D
Unread post by Tim_D » Wed Apr 19, 2017 9:34 am
I thought I'd keep a running diary of my project, and what better place than somewhere that another person may come across a similar issue!
My car is a '65 Monza Coupe that I purchased in November 2016. It's a 110/PG combo that is very original, and I plan to keep it that way (minus a few bolt-on appearance items, and maybe a safety item or two).
As purchased, the car requires some body work in the usual places (lower front fenders, lower quarters behind the wheels), as well as a few not-so-common areas (such as the driver's front fender). The good news is some typical bad spots, like the rockers, floors, door pillars, and lower windshield frames are all quite solid. Also, many trim parts are needed (front seat covers, headliner, carpet), and some engine overhauling will be on the list.
Below are some photos of the car's most obvious areas of need.
Driver's lower quarter
Passenger's lower quarter (not too bad)
Passenger's rear quarter lip
Fender opening
Also some of the areas that can wait a little -
Engine
Passenger's door jamb
Driver's door jamb
And a few images of the overall car as delivered (except the tires/wheels, which I added:
Regards
-TD
Tim_D
Re: 1965 Monza Coupe Thread
Unread post by Tim_D » Wed Apr 19, 2017 9:44 am
The first order of business was to replace the front springs. The car made a little noise over bumps... The reason was obvious!
Broken driver's front spring
The car sat a little better - level - on the driver's (broken spring side) than the passenger's. After seeing that pretty much one coil was broken, I decided to remove a coil from each new spring. I ordered a new set of standard duty replacements from Clark's and installed them, using resources on this site to guide me in this process.
Regards
-TD
rondo
Unread post by rondo » Fri Apr 21, 2017 7:27 am
Nice looking monza. Like the wheels.
Sent from my SM-G920V using Corvair Forum mobile app
1958 Chevy Impala
1966 Corsa Conv.
Who is online
Users browsing this forum: No registered users and 1 guest
