65ish Corsa Automatic
Re: 65ish Corsa Automatic
Unread post by bbodie52 » Wed Nov 23, 2016 4:14 pm
The chart referred to above is incorrect where it indicates that the 1965 Monza and Corsa interior code 798 is "Ivory". As shown in the chart below (from the 1965 Chevrolet Corvair GM Heritage Center Specs) indicates that code 798 is a two color black and white combination, with the carpet and instrument panel black.
1965 Chevrolet Corvair GM Heritage Center Specs.pdf
(2.01 MiB) Downloaded 8 times
SteveH
Unread post by SteveH » Wed Nov 23, 2016 4:22 pm
Perfect! THAT is what I needed! Thanks to all for the help!
and so this car was DD exterior color Mist (Med) Blue... cool
CORSA Member #034095
SteveH
Unread post by SteveH » Sun Nov 27, 2016 6:22 pm
With a little help from my Daughter we layed out the Yenko stripe
FLat White was SO the right choice instead of the usual black.
I decided this car need a center console and drink holders (front and rear)
this is 16ga steel (cause i have lots)
First test fit, seems like I imagined it
Rust coating done. Now it needs the wooden drink holder inserts, the top hinged cover, and it's white and black fabric covering.
and finally, got the Frunk mostly sorted out
toytron
Unread post by toytron » Sun Nov 27, 2016 6:39 pm
Man Steve, where did you get a hold of that nice long anvil? I bet that comes in handy for doing sheet work! Btw the stripe is looking good.
SteveH
Unread post by SteveH » Sun Nov 27, 2016 6:46 pm
I've been making armor for more than 25 years so I have a bit... that is called a beakhorn, I also have a blowhorn which is the stake used for making trumpets and other wind instruments. I have about a dozen or two homemade stakes specifically for the components that I make, so yeah hand metalworking wise I've got lots of toys
crogers
Unread post by crogers » Mon Nov 28, 2016 1:19 am
Cool,looks good with the white stripes!!
1960 500 coupe 3spd
1960 700 sedan pg.
1962 Monza coupe 4spd.
1962 spyder convertible
1964 Monza coupe pg.
1964 Monza convertible 4spd.
1966 corsa coupe turbo
vairsquared
Unread post by vairsquared » Mon Nov 28, 2016 5:06 pm
Good idea on the stripe layout!
SteveH
Unread post by SteveH » Wed Nov 30, 2016 10:24 am
Solved the harsh downshifting into 1st.... The Vacuum modulator works WAY better when the connector hose is actually connected.... MUCH smoother now... LOL
The engine is running better than ever but there is still a slight "lope" when sitting at stoplights/signs. Occasional misfires as well...
SteveH
Unread post by SteveH » Mon Dec 05, 2016 11:00 am
Birthday Upgrades!!! Front Air Dam, 15" Crager S/S's and 205/60R15's
Love my wife!!!
crogers
Unread post by crogers » Tue Dec 06, 2016 8:37 pm
Cool!! Congrats and happy birthday!!
1960 500 coupe 3spd
1960 700 sedan pg.
SteveH
Unread post by SteveH » Fri Dec 23, 2016 7:46 pm
Center console done. Will be installed Tomorrow after she gets out of the shop.
Took it to a GREAT local shop, same day service $190 to cut 1 coil from my fronts. I got a 1.25" drop.
Waiting until they close be stored inside waiting for the first AM appointment for brakes and alignment
BobWitt
Unread post by BobWitt » Sat Dec 24, 2016 9:47 am
Steve - similar to the "Field Find" you continue to inspire and amaze... Really good looking vehicle...
BobWitt - South East Michigan
Member: Corsa and DACC
1966 Corsa 140
SteveH
Unread post by SteveH » Sat Dec 24, 2016 3:16 pm
home!!!
crogers
Unread post by crogers » Tue Dec 27, 2016 8:27 am
Car is looking really good!! Great look!
1960 500 coupe 3spd
1960 700 sedan pg.
SteveH
Unread post by SteveH » Tue Dec 27, 2016 9:28 am
Thanks! Here it is with the console in place.
SteveH
Unread post by SteveH » Tue Apr 11, 2017 9:50 am
Getting one step closer to the point where I'm gonna have to change the thread title....
BIG thanks to Paul Kehler who provided these for only $250 each exchange!!!!
Who is online
Users browsing this forum: No registered users and 1 guest
