Engine Code
Engine Code
Found on a 65 Canadian Corsa...........
Scott Farnell
Calgary, Alberta
65 Monza (Corsa Clone)
Calgary, Alberta
Re: Need Help on Engine and Body Codes
Did a little more cleaning........... :)
Scott Farnell
Calgary, Alberta
Calgary, Alberta
Re: Found what I was looking for.....please ignore
T0129RH
0129 = Engine manufacturing date of January 29
RH = indicates a 1965-1967 Corvair 500 or Monza 110hp 164 CI engine with automatic Powerglide transmission.
I have attached some data pages extracted from the CORSA Technical Guide to help you with these codes.
- (1.25 MiB) Downloaded 34 times
Re: Engine Code
RH..........not what I was hoping for.
Thanks Brad!
Thanks Brad!
Scott Farnell
Calgary, Alberta
Calgary, Alberta
