please see attached (63 Spyder)
I know:
712 = Black Interior
948 = Palomar Red Exterior
First group
Second Group
C = RPO Padded dash
L = Manual trans (VN only)
Third Group
C = RPO Turbocharged Spyder option
P = (VN only) might be Comfort and Convenience
What does [ 30 ] stand for?
Regards,
Andy
63 Body/Tag
- wingnutandme
Re: 63 Body/Tag
1E = built in January, the letter equals the week, e= 5th week. January of 1963 has 5 weeks.
63-0927 = 63 spyder coupe
VN = it was assembled in Van Nuys, California 8875 = assembly sequence number
You've got the rest and I also do not know about the 30 in the Accessories. It may be a second set of third group of accessories with an O not 0. Do you have something unusual with the car, that could be classed as an accessory? some obsure ones have not yet been documented.
61 Rampside
Ultra Van #328
CORSA, Corvanatics, UVMCC, VCE
Corvanatics Secretary/Treasurer/Newsletter Editor
UVMCC Newsletter Editor
Cosworth & a Vega Kammback
80 TR7 Vert
Ultra Van #328
80 TR7 Vert
Re: 63 Body/Tag
Many thanks ....The only option I could think of would be the blinker for the emergency brake...wingnutandme wrote: Do you have something unusual with the car, that could be classed as an accessory?
Regards,
Andy
- wingnutandme
Re: 63 Body/Tag
Hi Andy,
You may want to look through this document from the GM Heritage Center (http://gmheritagecenter.com/docs/gm-her ... orvair.pdf" onclick="window.open(this.href);return false;) and see if you see something on your car listed on here. Your parking brake warning light is listed, but under the dealer installed accessories. Those would not show on a body tag. That tag was for Fisher to know what to install on the body that only they handled. You can see those listed in the section above the dealer installed items, but it's not always totally clear which were installed at the factory and what was installed by Fisher Body.
BTW, where are you located. Maybe take some pictures of your car. It sounds interesting.
61 Rampside
Ultra Van #328
80 TR7 Vert
Ultra Van #328
80 TR7 Vert
Re: 63 Body/Tag
I'm gratedful for the document.....here are some pics....obviously the A/C is not stock....wingnutandme wrote:Hi Andy,
You may want to look through this document from the GM Heritage Center (http://gmheritagecenter.com/docs/gm-her ... orvair.pdf" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; - and see if you see something on your car listed on here....Maybe take some pictures of your car. It sounds interesting.
Regards,
Andy
Re: 63 Body/Tag
the [ 3O ] might actually be a 30 (thirty)...please take a look at another Van Nuys 63 corvair:wingnutandme wrote: You've got the rest and I also do not know about the 30 in the Accessories. It may be a second set of third group of accessories with an O not 0
viewtopic.php?f=51&t=5371
Regards,
Andy
Re: 63 Body/Tag
Does you 63 Van Nuys built Corvair have these options?
RPO Z01 Comfort RPO Convenience Equipment:
Outside Rear View Mirror
2-speed Windshield Wipers and Washers
Back-up Lights
Glove Box Light
Inside non-glare mirror
The "30" was an internal audit code that was only relevant to the plant...
Back-up Lights
Glove Box Light
Rick Loving
Corvair historian & chronicler of useless facts
CORSA
Performance Corvair Group
Chicagoland Corvair Enthusiasts
RAL1963@COMCAST.NET
Just south of Chicago IL
Current Rides
63 Sprint Vert 140/4sp
CORSA
RAL1963@COMCAST.NET
Current Rides
