Engine ID # location
I thought I knew from a prior description where the engine ID number would be, but I can't seem t find it. Can somebody give me a detailed description of where the ID number on my engine can be found. It's awfully dirty, and I'd like to focus my cleaning efforts in the right location (since the carbs are still off and I can't use my power washer on it)
Thanks
Thanks
Re: Engine ID # location
In the middle of the block between the blower shroud and the oil filter/alt housing on the left case half at the part line by the oil pressure sensor.
This motor is partially disassembled but it will still show you where it is located.
If it is greased over, a shot of brakleen form the tube lights it right up.
Just SW of the oil fill cap in Scott's Pic.
Thanks guys. I'm used to vw stuff and was looking at the vertical surface below the fuel pump and alt... Getting my head into the engine compartment of the bus to see the top of the case will be tough, but should be doable. Worst case I can stick a camera in there and just take a photo in the hopes the number will be visible.
T08I7RH.
How much info can I glean from just this block number?
Engine No: T08I7RHscottydont wrote:T08I7RH.
0817 = Engine manufacturing date of August 17
RH = 110 HP Automatic Transmission (1965-1967 Corvair 500 and Monza)
Note: One of the engine compartment photos you posted earlier appears to show that you have a 95hp engine cast crankshaft pulley installed instead of the Harmonic Balancer that is required for 110hp and above 164ci engines. The original harmonic balancer probably failed at some point in the past, and to save money someone probably substituted the cheaper cast pulley. This could ultimately damage your crankshaft. Recommend purchasing a new or used/rebuilt harmonic balancer for your engine and toss the cast pulley.
The Cylinder Head casting numbers can tell us something about the engine, and so can the model number cast on the distributor. These numbers are more-difficult to view (head numbers are cast on the ends of the cylinder heads) but if you get these numbers we can determine if the distributor advance curve matches with an automatic transmission 1965-67 110 hp engine, and also if the heads are a match (3856743, 3856759, 3878561, 3878562, 3880707, 3880708, 3883858, 3883862, or 3878566 = 1965-69 110 hp).
EXAMPLE - Cylinder Head Casting Number Location
Regarding engine ID numbers: Imagine my surprise when I inspected this engine at a friend's house:
Marty Scarr
After talking to some knowledgeable folks about it, some of the replacement blocks sold through dealerships didn't have any ID stamp. Most of them did, having a engine suffix like "XXO" but a few of them had no marking at all. Doesn't make much sense.Marty Scarr
Head # is 3856759 (I only checked one, assuming they match). If I'm reading the chart in that link you posted correctly, that makes it a '65 110.
Couldn't find a # on the dizzy. Must be on the back side or underside?
It would be nice if somebody swapped the dizzy out to match the manual trans, but if they didn't, how much difference is there in the advance curves really? Enough to notice or make a difference one way or another? I live at 7K ft altitude, so I can get away with a lot more aggressive timing than most people.... Actually almost have to in order to make up for some of that 20% power loss vs. sea level.
It's very hard to see when installed. You might be able to see it with a mirror and will probably need some brake cleaner to clean it up a bit.scottydont wrote:Couldn't find a # on the dizzy. Must be on the back side or underside?
Good news here, the distributors are the same for manual and PG for your engine. Here's a spec sheet:It would be nice if somebody swapped the dizzy out to match the manual trans, but if they didn't, how much difference is there in the advance curves really? Enough to notice or make a difference one way or another? I live at 7K ft altitude, so I can get away with a lot more aggressive timing than most people.... Actually almost have to in order to make up for some of that 20% power loss vs. sea level.
Marty Scarr
That is good news. Scratch one more item off the list of potential fixes :)martyscarr wrote:
Marty Scarr
I'll still check the dizzy number, but it's definitely lower priority at this point. Just looking at that chart, it looks like some of the other models were definitely more aggressive and/or really set up for better highway economy. Not sure yet, but it looks as if there's at least some potential for benifit by changing to a different distributor.
The distributor number is difficult to see without removing the distributor, as it normally faces the engine. It is on the side of the distributor base housing, around spark plug wire number 5.
What would a block number T060YR mean?
http://www.angelfire.com/ca4/CorvAIRCRA ... uffix.html This is a chart link.
T060YR
060 = Engine manufacturing date (month and date). "060" is not valid, and appears to be missing a digit.
YR
YR
- 1962 150 hp, 145 CI, Manual Transmission, Turbocharged, Monza Spyder (Coupe or Convertible).
- 1963 150 hp, 145 CI, Manual Transmission, Turbocharged, Monza Spyder (Coupe or Convertible).
- 1964 150 hp, 164 CI, Manual Transmission, Turbocharged, Monza Spyder (Coupe or Convertible).
I'm sorry it says T0602YR. It was out of a 64 vair. But I can't determine what the HORSEPOWER is.
