Hidden vin locations!
Got a Body Tag that needs decoding? Post it here.
4carbcorvair
Post by 4carbcorvair »
First is em hidden vin location. Behind the front crossmember on the driver side.
Next is lm location. Behind the crossmember on the passenger side.
EARLY MODEL (EM)
LATE MODEL (LM)
You do not have the required permissions to view the files attached to this post.
Dirigo Corvair group.
4carbcorvair
Re: Hidden vin locations!
Thought I would ad this to try and keep all in one area. :)
viewtopic.php?f=51&t=3182
Rons64
Post by Rons64 »
Thank you for posting that. It's good to know exactly where to look. :tu:
Ron
More info for future searchers.
Here are my hidden VIN location photos for USA built 65-69 coupes and sedans.
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
zepplloyd
Post by zepplloyd »
Looking at the body tag in the engine bay. Can someone assist in identifying the info?
105676W127148, thanks in advance!
1966 Monza Convertible built at Willow Run and 27,148th Corvair car built in that model year at that plant.
http://1969corvair.com/techpages/Corvai ... _VINs.html
65 Corsa 140/4
66 Corsa 140/4
zepplloyd wrote: » Mon Jul 27, 2020 8:43 am
105676W127148
Chevrolet (1) Corvair Monza (05) 2-Door Convertible (67) 1966 (6) Willow Run (W) S/N: 127148
Sample Engine Compartment VIN Tag
Sample Engine Compartment Body Tag
This body tag is from a 1966 Corvair Corsa Coupe that was produced in the Van Nuys, California plant during the third week in December 1965. The car had a black interior with bucket seats that were fitted with optional headrests. The body was painted Chateau Slate, and the engine was turbocharged.
Body Build Date 12C — 12 (December 1965), C (Third Week), from a 1966 (66) Chevrolet (1) Corvair Corsa 10700 Series (07) 2-Door Sport Coupe, 4-Passenger (37) produced at the Los Angeles (Van Nuys) plant (LOS), Production No. 773, TRIM 758-Z Monza/Corsa Series with Bucket Seats/Black Interior (758), -Z (The extra digit denotes whether the car has optional headrests or not. E = headrests on bench or bucket seat cars built in WRN in 1966 and bench in1967. Y = headrests on bucket seat cars built in Los Angeles or buckets built in WRN in 1967. Z = Corvair trim designator on LA built cars only.) SLATE (Chateau Slate) Paint (W-W), 4O ACC = Accessory line Group 4, O = RPO L87 — Turbocharged Engine
I have attached a copy of 1966-Chevrolet-Corvair - GM Heritage Center Specs
:chevy:
Here is another example — this one from an Early Model — 1963 Corvair Spyder Convertible...
30967W108120
1963 (3) Corvair Monza (09) 2-Door Convertible (67) Willow Run (W) S/N: 108120
:link: viewtopic.php?f=52&t=16215
Beers wrote:At least with the crossmember out I got to see that the body VIN matches :tu:
my65
Post by my65 »
I am buying a 66 coupe with a vin tag 107376L102321 but the body tag is MISSING 😳😢 Is there a way to find out what would have been on the tag and purchase a replacement??!!🙏
Ed ( my65 )
110 HP 4 Speed
63 Monza Coupe
140 HP 4 Speed
Porter, Texas
107376L102321
There is some overlap in the Information in the Body Tag and the VIN Tag, such as the make and model, model year, production assembly plant, and you can possibly determine the original paint and interior colors and applicable codes from observation, as well as the ACC Line options included in your car (assuming that subsequent owners did not change or add those options to your Corvair after production). Some body tag info, like the production month and week, were only recorded on the body tag and that information is likely lost.
I have not heard of anyone reproducing body tags to order.
1966 Fisher bodytags ACC line. (WRN and LOS)
The Letters are listed in groups. Letters following a number is in that group. The code letters are listed in the order they would appear. Some letters are in more than one group
Most 1965 codes carried over to 1966 unchanged. (New std equip eliminated some codes)
First Group ( no numeric indicator)
E = RPO A01 Tinted Glass ( Soft Ray glass in all windows)
D = RPO C06 Power Top (Manual top standard, no indicator)
W = RPO A02 Tinted Windshield only
O = Two tone paint trimpiece ( sedans only)
L = folding rear seat (500 series only)
2 = Second Group
M = RPO M35 Powerglide Automatic
E = RPO C60 Air Conditioning
R = RPO U80 Rear speaker
S = RPO U73 Rear ant.
T = RPO U75 Power Rear antenna
H = Heater delete
3 = Third Group
A = Rear armrest (500 series sedans)
4 = Fourth Group
O = RPO L87 Turbo engine
F = Remote outside mirror / updated CC group (lighting grp, door guards)
5 = Fifth Group
Y = RPO A49 Deluxe Seatbelts ( Stainless Steel Push-button Buckles)
O = Seatbelt delete? ( No cars found with this code, but may carry over from 65)
? = Shoulder harness
*Standard seatbelts, old CC group and padded dash are now standard. So C in group three, P in group four and W in group five no longer listed. Also 4spd transmission no longer listed, with the introduction of the new Saginaw transmission. Rear seatbelts are also now STD. Willow Run cars had the ACC codes all on one line.
erco
Post by erco »
My '67 Monza coupe's VIN hidden behind the crossmember and the matching number in the engine room.
erco wrote:
Wed Sep 23, 2020 9:54 pm
Always nice to see those two match! Sadly, I've found a few that don't.
65 Corsa 140/4
66 Corsa 140/4
erco
Post by erco »
Who else would know, besides you and the guy who riveted the rear plate on? Do you just bolt the crossmember back on and sell the car?
Deadwolf
Post by Deadwolf »
So from what I am getting from this is the metal body itself does not have a VIN stamped in it. As long as a person found the correct rivets and rivet gun they could swap the VIN tag, front cross member, and engine compartment body tag and short of actually finding discrepancy between options no one would be able to tell they did it? Is this correct?
1963 Monza Spyder project
1964 Monza Parts car
Deadwolf wrote:
Thu Sep 24, 2020 9:54 am
No. The "hidden VIN" is hidden by the front cross member but is not on a part you can unbolt or swap easily. The hidden VIN is stamped into the frame rail and is an integral part of the body.
With enough financial motivation, anyone with bad intentions can figure out a way to swap a VIN and not get caught selling a stolen car or hiding salvage title history. The welded on tags, roset rivets and hidden VINs were the best trick of the day to help prevent VIN and title fraud.
Few people buying a car will check the hidden VIN and most have no reason to. If a seller is telling me they have a genuine 66 Corsa vert with factory A/C, you can be sure I'm looking all that over with a magnifying glass.
I've had two cars brought in from other states that had inspections go sideways. They go through a physical inspection at the DMV here in Arizona. Any sign that something isn't right and they will get scrutinized big time when they make you take the car to the state police garage for a Level III inspection. If anything is out of whack or they feel there is fraud when numbers don't match up, it could be the last time you see your car. I got both of those cars cleared but one now carries a "Restored Salvage" title which lowers the value and sometimes limits how much comp insurance coverage you can get. That car had a "washed" title and when I took the seller to court I found out he had already been arrested for doing the same thing to someone else.
65 Corsa 140/4
66 Corsa 140/4
erco wrote:
Thu Sep 24, 2020 9:43 am
You could do that but if the new owner finds out he bought a VIN swapped car from you it will be up to you to prove you didn't know about it or actually have anything to do with it.
65 Corsa 140/4
66 Corsa 140/4
Return to “Body/VIN Tag Decoding”
