ACC Code on 62 Monza
gregger59
Post by gregger59 »
Good morning and happy Labor Day weekend,
I am looking at a 62 Monza convertible whose Fisher tag is pretty readable to me, thanks to the GM Heritage Center Guide found here for 1962.
However I am apparently not looking in the right place for Accessory info; the page at the back of the guide does not show any letter codes.
The plate reads: ACC ADHL + 10 (I think it's a plus sign; a little blurry under the paint...could be a dash.)
Any thoughts? Thank you in advance!
P.S. The paint code, 923-5, matches the color on the car (Roman Red), although I don't know what the "-5" means...
Thanks again.
gregger59
Re: ACC Code on 62 Monza
Post by gregger59 »
Ha. As often happens, I ask a question and then keep digging to find the answer! Anyway, after finding mostly broken links to Corvair Gold, I did find a good one and downloaded the .pdf of this incredible guide to
https://www.dropbox.com/sh/cm8reltt5ztsn2r/qiV5kD-NmO
And there, behold...
A - Direct air heater
D - Spyder
H - Padded dash
L-1 Convertible Top, White
O - Manual trans (I had thought it was a zero)
and the -5 after the Roman Red paint code indicates Red Interior Paint.
FYI and thanks for reading. Happy holiday.
Corvair Gold is a great resource!
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
