Color Code
Color Code
Hi all! Going over the 65 Vair Corsa that was bequeathed me by my Dad. Can anyone tell me if there is a color designation within the VIN or other numbers on the car? I’m noticing some red showing through where the yellow is chipping at the door lock latches on the body. I’m thinking the car was originally red. And yes I’m aware there aren’t supposed to be good vents on the front
'65 Corsa Convertible
Re: Color Code
Color code is on the metal tag on top of the rear crossmember behind the distributor. It is a stamped rectangular tag that has trim color and options listed on it.
Re: Color Code
Great thanks! I’ll look for itterribleted wrote: ↑Sun Jun 30, 2019 8:01 am Color code is on the metal tag on top of the rear crossmember behind the distributor. It is a stamped rectangular tag that has trim color and options listed on it.
Re: Color Code
Here are sample pictures of the 1965-69 Passenger Car Body Tag and VIN Tag (both in the engine compartment, riveted to the perimeter frame near the battery and the distributor)...
VIN Tag
Body Tag Sample
To decode the Body Tag, click on the following link...
A guide to body tag decoding resources on the web
viewtopic.php?f=51&t=4321
This will help with the VIN Tag...
VIN Tag
Body Tag Sample
Re: Color Code
bbodie52 wrote: ↑Sun Jun 30, 2019 9:24 am Here are sample pictures of the 1965-69 Passenger Car Body Tag and VIN Tag (both in the engine compartment, riveted to the perimeter frame near the battery and the distributor)...
VIN Tag
Body Tag Sample
Thanks!
