Assistance Needed in Understanding Body Tag
Spike65
Post by Spike65 »
Based on the body tag on a Corvair I saw this is my understanding:
Built in November, 2nd week (11B)
Model year = 1965 (65-10767)
1 = Chevrolet
65 = 1965
07 = Corsa
67 = 2 door convertible
Produced at Willow Run (WRN)
Production sequence = 32,685 (W132685) from VIN tag
Interior trim = red (785)
Body color = white (C2)
2L3C4U-
4 speed tranny 2L RPO M20
Padded dash 3C RPO B70
Spare tire lock 4U RPO P19
What does 11C5 Body mean?
Is it a 110 HP engine or something else?
Did I miss anything else in reading the body tag info?
I was told that not all options are shown unless it affected the body build. So the standard AM radio would not be mentioned for example.
It also has the single speed wiper, which I believe was standard.
Thanks
Dave
Re: Assistance Needed in Understanding Body Tag
:wave: :welcome2: Welcome to the Corvair Forum!
BODY TAG INFO:
11B
Body Build Date: 11 = November, B = Second Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. If the letter is an "B" it indicates the second week of the month.
Interior paint code: D = Red
65-10767 WRN 1105 BODY
Style: 65 = 1965 10767: 1 = Chevrolet, 07 = Corsa, 67 = 2-Door Convertible 4-Passenger,
WRN = Willow Run, Michigan, Production Sequence No: 1105
1965 Chevrolet Corvair Corsa 2-Door Convertible - 4 Passenger, Total Production: 8,353
TRim: 785- = RED (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
This 3 digit codes represents the interior color and seat type.
Paint: C-2 = WHITE "Ermine White", Top Color Code: 2 = BLACK
Lucite No. 4024L, Rinshed-Mason No. A1199, Ditzler No. DDL 8259
Example — 1965 Corvair Corsa Convertible in Ermine White with Red Interior
ACC = Accessory line
2L 3C 4U
GROUP 1
NONE
GROUP 2
L = RPO M20 — 4 Speed Manual Transmission
GROUP 3
C = RPO B70 — Padded Dash
GROUP 4
U = RPO P19 — Spare Tire Lock
GROUP 5
NONE
Spike65 wrote:Thu Apr 20, 2017 7:16 pm
...My Name is Dave and I live in Central New Jersey. I have just purchased a 1965 Corsa turbo...
I pulled this from an earlier posting. If your Corsa was originally a turbo, it would have Accessory Code "O" in ACC Group 4 (O = RPO L87 — Turbo engine). If your Corvair has a turbocharged engine now, it was probably added by an owner after the original purchase. All other Corsas were fitted with a standard 140 hp 4x1 engine. (Turbo Corvairs have a special exhaust pipe cutout on the right in the body, below the bumper, which can be seen in the example below).
This guide will show you how to decode the VIN tag...
107675W132685
I have attached a copy of the 1965 Chevrolet Corvair GM Heritage Center Specs for your model year Corvair.
(2.01 MiB) Downloaded 31 times
:chevy: :welcome:
Spike65
Post by Spike65 »
HI Brad
Thank you. Is there an indication of the original motor?
Dave
bbodie52 wrote:If your Corsa was originally a turbo, it would have Accessory Code "O" in ACC Group 4 (O = RPO L87 — Turbo engine). If your Corvair has a turbocharged engine now, it was probably added by an owner after the original purchase. All other Corsas were fitted with a standard 140 hp 4x1 engine. (Turbo Corvairs have a special exhaust pipe cutout on the right in the body, below the bumper, which can be seen in the example below).
You may not have see the line I added above. There was no special ACC code for the standard 140 hp engine. The special turbo engine exhaust cutout did require a body change, which would explain the Body Tag code "4O".
Spike65
Post by Spike65 »
Brad
I completely understand and you have verified what I understood from reading your previous detail posts. Again many thanks.
:dontknow: Your body tag may have been removed at some point and then riveted back into place. It is possible that it is not even the original body tag. The rivets holding your body tag to your car (shown above) do not match the style of the original rivets used to secure body tags in Corvairs. Multiple examples of original body tag installations are shown below. The first body tag also includes the letter "O" in group four, as an example of a Corsa that was originally fitted with the turbocharged engine (in this case a 1966 Corsa coupe from Van Nuys).
:chevy:
Krfjkm
Post by Krfjkm »
Hi Brad-- I've attached my body tag and have a question. If I read my tag right my car was made in the 3rd week of June...right? I also interpret it to be production number 6747.
Why would mine be made in June and production sequence 6747-- and the one in this thread was made in November and production sequence 1105?
I am sure it something I am missing--- can you help?
1965 Corvair model year production began around September 1964 and ran through August (or early September) 1965. The 1966 Corvair was then introduced in September 1965.
...I've attached my body tag and have a question. If I read my tag right my car was made in the 3rd week of June...right? I also interpret it to be production number 6747.
The 1965 Corvair body with production sequence 1105 was made by Fisher Body in the second week of November 1964 in support of final production at the Willow Run, Michigan plant. It was the way GM Detroit markets things.
:chevy:
Krfjkm
Post by Krfjkm »
:ty:
So my car was made the 3 week of June-- right?
64powerglide
Post by 64powerglide »
Yuppers!
JUNE 1965 CALENDAR.
Su Mo Tu We Th Fr Sa
01 02 03 04 05
06 07 08 09 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Krfjkm
Post by Krfjkm »
Thanks! That is what I thought --- my car is one month older than me!
