VIN Question
cwhunt
VIN Question
Post by cwhunt »
After reading how the VIN is broken down, I recently purchased a '63 Coupe and developed a question regarding the VIN. I know the vin has a letter in it indicating which factory that it was built in. I know mine was built in Oakland from the body tag, so my VIN should have the letter O in it. I see where it should be, but the supposed O looks exactly like a zero. So, I believe it should be a letter when doing the paperwork. Does any have their VIN recorded as containing a zero instead of the O for Oakland?
Sent from my SAMSUNG-SM-N920A using Corvair Forum mobile app
Christopher Hunt
San Diego, CA
'63 Monza Spyder 150HP Turbo
Re: VIN Question
It would not be unusual for the workers in the plant to use the same stamp tool to produce a zero (0) and the letter "O". Your VIN tag decodes as a 1963 Monza Coupe produced in Oakland, California.
acarlson
Re: VIN Question
Post by acarlson »
I would be concerned if your Vair was titled with a "0" rather then an "O" since the VIN on the Title would not match the the VIN format defined by the manufacturer for your car.
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
benfro
Re: VIN Question
Post by benfro »
I have a 62 Spyder built in Oakland. The VIN tag shows a "0" and not a "O". The title and the number on the car should hopefully be the same (with a "0"). If no title, I would keep it the same as the written on your tag when applying for one.
cwhunt
Re: VIN Question
Post by cwhunt »
I am submitting the paperwork and I am concerned with what to put. I think I will go with a zero simply because the laymen would look at the tag and say it's a zero and not the letter O. Placing the letter O on the paperwork might produce headaches down the road.
Christopher Hunt
San Diego, CA
Re: VIN Question
It is meant to be recorded as the letter "O' and I would submit it as such. Any reasonable state vehicle inspector will understand the VIN numbers of that era and a "layman" is not who you need to worry about. When you submit the VIN later, to an insurance company for instance, or maybe a future buyer, they will expect to see a letter and not a number in that position.
MtnVairMike
Re: VIN Question
Post by MtnVairMike »
Submit it on your paperwork as it is supposed to be for the VIN features/options and let the reading/interpretation chips fall where they may.
If you get it wrong on the title it's tough to get it corrected through DMV. Ask me how I know....
Thanks,
Mike
