66 VAIR-8 Project
Vair-8
66 VAIR-8 Project
Post by Vair-8 »
This is a project that has been going on for some time. The original post was put in the performance topic page and I thought it should be here. This has been going on for several years now due to some set backs and working around a busy work schedule. We now have two vair 8's, this one is a 66 and my fathers is a 68. Our goal is to get this one on four wheels and then work on my fathers because it is further along. Will post his car later.
Where car was found
Where car was found
Charles Troutman Sr.
Charles Troutman Jr.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Vair-8
Re: 65 VAIR-8 Project
Post by Vair-8 »
Here is what body looks like. Windshield has worst of rust. Some little rust in qtr. panels.
windshield
windshield
not rust in floor
not rust in floor
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Vair-8
Post by Vair-8 »
This is how engine looked, will not be using this set up. Have different engine and conversion.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Re: 66 VAIR-8 Project
Keep doing a little work each week. Eventually you'll get it on the street,
So many projects...so little time.
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
Vair-8
Post by Vair-8 »
Front disc brakes done, check
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Vair-8
Post by Vair-8 »
Engine installed, check
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Vair-8
Post by Vair-8 »
Tranny installed, check
Rear support bracket installed, check
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Vair-8
Post by Vair-8 »
Love this view :rafman:
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Nice progress, thanks for the updates.
I'm drooling..... :drool:
Vair-8
Post by Vair-8 »
Installed alternator and belt.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
hrm2k
Post by hrm2k »
It looks great !!!!
I was wondering as to the leg room. It looks like the water pump / accessory section is actually in front of the door jam. How much room will you have for seats and your legs ?
Vair-8
Post by Vair-8 »
I'll take a picture of side view from door frame. This kind of set up doesn't leave much leg room. I will be installing a swivel on the bottom of my seat so I can sit first than turn in. I got this idea from another vair-8 conversion. I will also install a grant steering wheel without the spacer to reduce length. Clarks use to sell panel so you could extend the floor which moved back the pedals to give more leg room.
The engine actually is further up than normal because we went from a manual to a auto tranny set up.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Phil Dally
Post by Phil Dally »
HOT ROD!!!
Paso Robles CA
CORSA Member
Plus 5 Chapters
Sidewinder SCTA
Unsafe at any Landspeed
LA Angels fan since 1978
So Cal Gas Co Since 1974
Retired After 40 Year Career
Vair-8
Post by Vair-8 »
Little set back this weekend. We thought with new power glide conversion it move the engine where we wouldn't have to modify the cross member. Will after installation it is still a little to close. There is a little gap but not enough for any kind of movement. We pulled out the cross member and will have it cut and welded. This will hold up the installation of rear arms and struts.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Vair-8
Post by Vair-8 »
Didn't like position of alternator. With leg room being at a minimum the alternator came to close with angle of seat. We ordered a new bracket and relocated the alternator which gave more room.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
