65 corvair disc brakes
I am going to be receiving a 65 corvair 4 door 140 on January 15th. I am going to get it running and I am pretty confident of what it needs. this will be my daily driver so I would like to know what it takes and how much it is to do a disc brake conversion.
Re: 65 corvair disc brakes
Depending on the kit . First thing I would do to a 65 is buy the dual master cylinder kit. Which makes front and rear braking independent and the corvair much more responsive on manual brak ing power.
Then when u have the kit. Front disks are the only upgrade you will need on a street corvair.
Are there any other vehicles that i can get the disc brakes from?
The Vair "kits" usually include rotors and calipers from other cars. The kit makers have done all of the homework for you and provided a nice adapter bracket. Most require you to machine the hub slightly.Jonathan's61vair wrote:Are there any other vehicles that i can get the disc brakes from?
Scarebird makes brakets if you want to do it on you own. Search around and you'll find discussions on S-10 rotors and calipers as well as many other GM vehicle options.
Buy this and then get the rest on your own from local stores.
http://www.ebay.com/itm/Chevrolet-Chevy ... 1135578594
I used the scarebird brackets and after gathering all the parts and machine work needed ( S10 Calipers, Blazer Rotors, 20" Braided Lines, Hub center hole turned 1/8 inch larger, Dual master, pads ) I'd say all in all I spent close to $800 to do the conversion........if not more. Although parts in the USA are cheaper expect to get close to this figure. Is it worth it? Dunno, I don't have it on the road yet.
Scott Farnell
Calgary, Alberta
65 Monza (Corsa Clone)
Calgary, Alberta
I think most people using my kits end up spending around $350
- coleslaw31
I got mine priced at around $300-350, i plan to do them with a front end rebuild this spring.
Greenville South Carolina
CorsaSC chapter
68 convertible
66 Corsa coupe
CorsaSC chapter
68 convertible
66 Corsa coupe
Did you do the rear? I'm in the middle of that now and am having some fitting problems.
