Need plans for/or corv8 input shaft and adapter
Having trouble finding that special part you need? Post a wanted ad.
Jim Hepler
Unread post by Jim Hepler » Thu Oct 19, 2017 1:37 am
I need the plans for building the corv 8 input assembly or what input shaft to use or a shaft and adapter. I have a complete machine shop and even broken parts will help. Even pictures would be helpful.
rfw66
Re: Need plans for/or corv8 input shaft and adapter
Unread post by rfw66 » Thu Nov 02, 2017 6:25 am
There was a Corv-8 book published in early 2000s.
I think it was s history and tech guide. What you are looking for may be in that book.
If someone on the V8 registry still has their Crown manual the information should be there as well. Good hunting!
Bob W
68 Monza coupe
acarlson
Unread post by acarlson » Thu Nov 02, 2017 7:14 am
There is some basic info here: http://www.corvair.com/user-cgi/catalog ... ge=OTTO-29
Alec
rfw66
Unread post by rfw66 » Tue Dec 05, 2017 8:00 am
rfw66 wrote:There was a Corv-8 book published in early 2000s.
Update. I found loads of info on the V8 registry. They’ve even published a copy of the Crown manual and the BPs of the subframe!
Bob W
68 Monza coupe
notched
Unread post by notched » Wed Dec 06, 2017 3:09 pm
You should look for Mike Levine. He is the Crown Corv8 guru. He lurks on the other forum as V8vair and on the Corvair Racers page on Facebook. He has a lot of stuff and knows what has to be done.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Return to “Parts Wanted”
