Differential
Having trouble finding that special part you need? Post a wanted ad.
eriiczilla
Differential
Unread post by eriiczilla » Thu Apr 13, 2017 10:15 am
Hey everyone! I'm looking for a good used differential to a 1960 with a powerglide. I'm in the socal area.
SteveH
Re: Differential
Unread post by SteveH » Thu Apr 13, 2017 11:21 am
Check with Paul Kehler kehler.paul@gmail.com
I just picked up a sweet trans and diff for a great price from him. he has LOTS of experience and lives north of San Diego
My Rebuilt Diff was only $250
CORSA Member #034095
eriiczilla
Re: RE: Re: Differential
Unread post by eriiczilla » Thu Apr 13, 2017 12:24 pm
SteveH wrote:Check with Paul Kehler kehler.paul@gmail.com
Thank you so much! I appreciate the help.
SteveH
Re: Differential
Unread post by SteveH » Thu Apr 13, 2017 2:52 pm
:tu:
two2brew
Re: Differential
Unread post by two2brew » Thu May 11, 2017 7:43 am
Have you contacted Paul? I know he has 2 EM powerglide differential cores but he is pretty busy.
64 Monza Convertible
eriiczilla
Unread post by eriiczilla » Wed May 24, 2017 6:13 pm
two2brew wrote:Have you contacted Paul? I know he has 2 EM powerglide differential cores but he is pretty busy.
I did! And he got back to me with a price which I agreed upon and after that communication stopped. I've sent follow up emails but I haven't received anything back. It's been about a month. :(
cnicol
Re: Differential
Unread post by cnicol » Wed May 24, 2017 8:02 pm
If you can't find one locally, I have a good and recently run '60 PG diff. It's all clean and resealed. The only issue is I'm in North Idaho. Last year I resurrected a '60 and installed this transaxle from my stash. The diff was fine but the attached PG was not so fine. Another transaxle from my stash went in and the one I'm offering came out. You could take or leave the attached PG but there's metal in the ATF so probably would do best to leave it. :tu:
Re: Differential
Unread post by 66vairguy » Thu May 25, 2017 10:01 am
If you are in SoCal check with the folks at South Coast Corsa. Member Dan Drommerhausen does trans and diff work and may have a lead.
Call SCC Prez. Chuck Rust at his business and see if he can help - (310) 679-7443
gnrand
Re: Differential
Unread post by gnrand » Fri May 26, 2017 6:28 am
Dan is a great guy; he built my 4 speed and diff. He too can be difficult to get in contact with because he only has a land line and certain morning hours that he answers the phone (I think 8:30 to 10 am). Have to let it ring because no way to leave him a message but it would be worth your effort. Located in Long Beach.
Jeff
1965 140 Corsa
1965 Corsa Convertible
1986 Buick GN V6 600hp
Re: Differential
Unread post by 66vairguy » Fri May 26, 2017 9:30 am
Jeff
Ohhhh don't call Dan before 9:45 or he'll be grumpy - LOL. Like most of us he gets a lot of junk telemarketing calls. So his method is not to answer the phone unless it rings at least TEN TIMES. That eliminated the junk calls. - What can I say - it works. Best time to reach him is around 10:00AM and 5:00PM.
BTW -- I talked with SCC Prez Chuck Rust and someone just donated an early differential that Dan is going to rebuild for the club to sell/raffle off.
Return to “Parts Wanted”
Who is online
Users browsing this forum: No registered users and 1 guest
