LM engine valve cover...
Having trouble finding that special part you need? Post a wanted ad.
acarlson
Unread post by acarlson » Thu Mar 16, 2017 3:30 pm
I will be doing a major rebuild of my Corsa turbo engine in the next month or so. I'll eventually need to adjust new lifters. So, I'm looking to acquire an engine valve cover that I can cut in half to use as an oil drain for adjusting the rockers and lifters. If you have one laying around that you're not going to use and you're willing to send it my way, PM me and let me know what you want for it.
Thanks -
Alec
corvairnorm
Re: LM engine valve cover...
Unread post by corvairnorm » Thu Mar 16, 2017 6:32 pm
I have a set of two covers, already cut in half. $10 plus shipping for the pair.
Norm Wright
Central Florida Corvair
Southeast Corvair Council
Corsa
63 Monza Convert
64 Spyder Convert
66 Corsa coupe-air conditioned
Scott V
Unread post by Scott V » Thu Mar 16, 2017 8:00 pm
nothing wrong w/adjusting the valves w/the engine running. but theres no good reason to do it that way & its alot ez-er to adjust them cold - just like the factory did & like its explained in the shop manual.
both ways work & both ways can be done wrong. do it the way you know - the result is the same if done right.
-Scott V.
notched
Unread post by notched » Fri Mar 17, 2017 6:10 am
I have been adjusting them with the engine off. Has been working great for me. No muss no fuss :)
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Return to “Parts Wanted”
Who is online
Users browsing this forum: No registered users and 1 guest
