NO LONGER NEEDEDWANTED /CAL CUSTOM AIR CLEANER ADAPTORS
Want to buy 4 Cal Custom adaptors used to mount small chrome air cleaners on individual carburetors.Any help appreciated, thank you Duke
Last edited by jmcasaleiz@gmail.com on Thu May 30, 2024 8:42 am, edited 1 time in total.
- davemotohead
Re: WANTED CAL CUSTOM AIR CLEANER ADAPTORS
I just sold a set 2 weeks ago, I guess these were used on some Yenko models, maybe the stage 1 & 2 street versions? I had 3 sets of them and have one set on my Corsa and sold the other 2 sets to Yenko guys. Personally although cool I think they are not that great, they don’t seal well to the top of the carb and the set screw always comes lose and they fall off, I had to drill a tiny divot in the carb body and make a pointed set screw much like the fuel pump bolt so the screw would have a nice place to sit and then put lock tight on the screw so it wouldn’t back out, that seems to keep them on better, Good luck in your search!
Hi Dave,
Thanks for your input. What aircleaners are you running? Could you send a photo? Thanks, Duke
- davemotohead
I put a longer center screw in them and doubled up (Stacked) the air cleaner elements for more flow, you can see the bottom filter in these pics, I also added a PVC system to them. before I did the set screw mod they would always fall off. I sold the other 2 sets for good money to Yenko guys because I thought these things sucked! LOL
- corvair parts 210.jpg (76.1 KiB) Viewed 191 times
- corvair parts 209.jpg (159.33 KiB) Viewed 191 times
- corvair parts 207.jpg (133.39 KiB) Viewed 191 times
- corvair parts 208.jpg (153.63 KiB) Viewed 191 times
- corvair parts 280.jpg (69.75 KiB) Viewed 191 times
- corvair parts 281.jpg (66.88 KiB) Viewed 191 times
- corvair parts 279.jpg (66.2 KiB) Viewed 191 times
