66 Turbo long Block with heads, clutch and flywheel
Buy or Sell Corvair parts.
pvholgado
Post by pvholgado »
This is a turbo long block (technically much more than a long block) that I took out of a running car-unknow miles but it ran without smoking and produced about 7psi boast. I built another motor that was an upgrade from this- I do not have any info. on the engine internals as I was not given any info on make up or components- (ie. cam, cylinders, crankshaft, deep seats? etc.)- Engine ran fine but I wanted to build one exactly as I wanted- I have many of the parts to make this a complete engine- from an "almost" complete turbo shroud set, to a rebuilt Alternator and starter. all available at extra cost **(Distributor that is included is NOT a turbo distributor with advance retard can) FYI, To build a complete turbo motor you would be spending close to 5k- thanks for looking. PM me with questions. Local pickup only.
pvholgado
Re: 66 Turbo long Block with heads, clutch and flywheel
Post by pvholgado »
Forgot this pic
pvholgado
Post by pvholgado »
scottymac
Post by scottymac »
Phil,
Will you sell without the heads? What price did you have in mind? Are you in New York?
pvholgado
Post by pvholgado »
I may eventually sell w/o heads-- right now this is together and I just mounted the turbo and YH that was on it along with an almost complete set of shrouds- trying to sell it as a plug and play- price has been adjusted to reflect the fully functioning turbo and YH as well as the shrouds. Stay tuned- thanks for looking.
pvholgado
Post by pvholgado »
This item has been modified and is no longer for sale in the stated configuration- A new post will soon be submitted. Stay tuned.
Return to “Parts For Sale”
