1965, 1966 140 engine. Code RN
Buy or Sell Corvair parts.
PaulR
Unread post by PaulR » Mon Oct 30, 2017 4:37 pm
140 h.p. engine for parts. Pretty much complete. Seized right now but I will try to get it unstuck. Lots of usable 140 specific parts: cylinder heads. oil cooler, distributor, secondary carbs and linkage and exhaust logs. Best offer on the whole thing. Got it from a guy that said "it ran when parked", ha, ha, ha, and I was going to do something with it, but now, not so much. Located in the Fox Valley in east central Wisconsin. You pick it up. Update: I did get it unstuck and it turns freely. I wrote that in a later post too. Also it looks like it is a 1966-68 engine, judging by the four larger bolts used on the top of the cylinder heads. Both cylinder head numbers read 3878570, which further narrows it down to a 1966 non smog engine.
1964 Monza convertible 110/PG
MtnVairMike
Re: 1965, 1966 140 engine. Code RN
Unread post by MtnVairMike » Tue Oct 31, 2017 12:41 pm
What car was the 140 RN code used?
Mike
Unread post by terribleted » Tue Oct 31, 2017 12:51 pm
65-68 Powerglide 140 HP
Trip
Unread post by Trip » Tue Oct 31, 2017 3:28 pm
There is a difference in PG 140's, related to the cam I think? I'm rusty after a couple years away!
Ray "Trip" Rodriguez III
Gouldsboro, PA
66 Corsa 140 coupe
64 Monza Convertible
gnrand
Unread post by gnrand » Tue Oct 31, 2017 3:51 pm
Crank is 4 degrees retarded. Would need an off set key to use it for a 4 speed I believe.
1965 140 Corsa
1965 Corsa Convertible
1966 Crown V8
1986 Buick GN V6 600hp
Unread post by terribleted » Tue Oct 31, 2017 4:01 pm
This
skipvair
Unread post by skipvair » Tue Oct 31, 2017 5:38 pm
Isn’t the gear vs the crank offset?
PaulR
Unread post by PaulR » Wed Nov 01, 2017 9:12 pm
Got it loose yesterday by pouring Liquid Wrench down the spark plug holes. The crank turns freely now.
Trip
Unread post by Trip » Thu Nov 02, 2017 12:05 pm
I thought it would be fine to use a PG 140 in a manual trans car, but that it's not a good idea to use a manual trans 140 in a PG car.
Gouldsboro, PA
66 Corsa 140 coupe
PaulR
Unread post by PaulR » Sat Nov 04, 2017 12:26 pm
Yes, probably best to use the engine in a PG car. No Frankenstein cobbling or other silly stuff. I am a factory stock guy myself.
wv-geo
Unread post by wv-geo » Wed Nov 08, 2017 8:19 am
I have a PG 140HP with a 4spd in my 64. Runs great.
It gives you more low end grunt up to 3000rpm at the cost of top end power.
Dan
1961 500 Lakewood, 80HP, PG
1964 500 Coupe, 140HP, 4spd (Christene)
1965 Mustang Coupe, 200cid 6cyl, 3spd
Return to “Parts For Sale”
