66 Corsa 140 with factory air conditioning
(Corvair ads you find on other sites can also be discussed here, i.e. ebay, craigslist.)
corvairnorm
Unread post by corvairnorm » Thu Oct 19, 2017 6:12 am
A friend has a 66 Corsa coupe with factory installed air conditioning. The car runs and drives, but needs a gas tank and brake work. The body is basically very solid, but does have some rust. The doors and lids all line up well, and open and close properly. The engine has a center mount four barrel, but otherwise, the car seems to be all original and unmolested. The a/c system is complete and closed, but inoperative. The interior is pretty good except for the carpet and headliner. With a bit of work, this car could be a daily driver, but to make it nice, it will need body work and paint, and the previously mentioned items. The car is located in Central Florida. We believe that about 150 of these air conditioned Corsa models were built, and certainly not many of them still exist.
Asking price is $5500, including a gas tank and whatever brake parts will be needed. Everything is negotiable.
Norm Wright
Central Florida Corvair
Southeast Corvair Council
Corsa
63 Monza Convert
64 Spyder Convert
66 Corsa coupe-air conditioned
62 Rampside
rondo
Re: 66 Corsa 140 with factory air conditioning
Unread post by rondo » Sun Oct 22, 2017 9:53 am
I have a 66 Corsa conv 140hp with factory air. Was wondering how many of the 150 Corsas built were convertibles with factory air. Btw , mine is completely restored and won Corvair of the month for April 2015.
1958 Chevy Impala
1966 Corsa Conv.
notched
Unread post by notched » Mon Oct 23, 2017 5:26 am
There seems to be quite a few of them out there. There are upwards of 30 of them accounted for. They were only made at Willow Run or LA. Rarest would be an LA build coupe. The LA build convertibles would be the rarest.
The number supplied by Dave Newell was 153 produced and this was based on the total RR coded blocks (the a/c Corsa specific block code) that Tonawanda produced. GM did not keep any other specific production records.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
Unread post by azdave » Mon Oct 23, 2017 6:11 am
He should have a pic of the body tag, VIN and engine code ready for buyers who want to be sure this is really one of those rare models. I've seen quite a few of these that are converted after the fact. I know of two in Arizona that are clones but are presented as being genuine (not Rondo's). It's a shame it was converted to a single, center carb but the old parts can be sourced for a restoration if desired.
The A/C Corsas are a rare Vair. I'll bet there are 50-75 still around of the estimated 150 built. I have two and know where a third un-restored hardtop is sitting. I gave about half that for one about a year ago in similar shape but it was missing the RR engine case.
65 Corsa 140 4-speed
66 Corsa 455 Toro V8
65 Monza 455 Toro V8
65 Monza 4DR EJ20T w/5-speed
corvairnorm
Unread post by corvairnorm » Tue Oct 24, 2017 5:37 am
I can supply pictures of the vin and body tags. I'll get them posted. I am not sure that the engine code is RR. I do have carbs and linkage to return it to stock.
Norm Wright
Corsa
63 Monza Convert
64 Spyder Convert
62 Rampside
Unread post by azdave » Tue Oct 24, 2017 5:56 am
If you have all the parts to return it to stock and the VIN, body tag and case code numbers and dates all agree, that should really help to hold the value.
corvairnorm
Unread post by corvairnorm » Wed Nov 08, 2017 9:22 pm
I do have all the parts to return to stock. We have lost our storage, so need to sell. Currently asking $4900
Norm Wright
Corsa
63 Monza Convert
64 Spyder Convert
62 Rampside
Unread post by azdave » Thu Nov 09, 2017 5:57 am
Again, I will recommend posting pictures of the VIN tag, body tag and engine case code so people can see it is a genuine 66 Corsa with factory A/C.
That might get you some more attention. I see a few things that hint that the engine might not be an RR code and that the A/C might have been added later. After 50+ years you never know.
corvairnorm
Unread post by corvairnorm » Tue Nov 14, 2017 7:56 pm
Norm Wright
Corsa
63 Monza Convert
64 Spyder Convert
62 Rampside
corvairnorm
Unread post by corvairnorm » Tue Nov 14, 2017 7:57 pm
Having trouble posting. Will try again for the engine code
Norm Wright
Corsa
63 Monza Convert
64 Spyder Convert
62 Rampside
Unread post by azdave » Wed Nov 15, 2017 7:36 am
Thanks for the VIN and tag pics. Info on the body tag confirms a 66 Corsa hardtop with factory air.
The engine code is a big deal to someone going for a full stock resto. The rivets on the VIN tag looking suspect so I would want to see the hidden VIN if I were a potential buyer. Plain rivets were found on early 65 production but as far as I know, both Willow Run and Van Nuys used roset rivet heads after 65.
Unread post by bbodie52 » Wed Nov 15, 2017 9:34 am
corvairnorm
Unread post by corvairnorm » Sun Nov 19, 2017 9:27 pm
I had thought of confirming the hidden vin number. I believe this is the genuine deal, but I'll try to confirm. BTW, owner says to drop the price to about 4k
Norm Wright
Corsa
63 Monza Convert
64 Spyder Convert
62 Rampside
corvairnorm
Unread post by corvairnorm » Thu Nov 30, 2017 6:24 am
The car has been sold. Thanks to everyone for your input.
Norm Wright
Corsa
63 Monza Convert
64 Spyder Convert
62 Rampside
Return to “Vehicles For Sale”
