1963 CORVAIR FOR SALE ! Anderson Ca.
(Corvair ads you find on other sites can also be discussed here, i.e. ebay, craigslist.)
jlm1182
Unread post by jlm1182 » Thu Aug 10, 2017 1:51 am
1963 Chevy corvair
fuel: gas
title status: clean
transmission: automatic
I don't have the time to finish this project, I have other stuff to do.
New brake shoes, cylinders, lines and master cylinder.
New wheels and tires
New weather stripping
Springs adjusted
New door locks
New ignition switch
The gas tank has been removed and boiled, checked for leaks and had a new sending unit put in and reinstalled
GM 1 wire installed
Updated H4 headlights with halos
New headliner ( still in box)
The stock motor with the steel Fin fan blades ( 80 HP) was locked up so a 1966 engine (102 HP) with the mag blades was put in. The engine has about 100 miles on it since the rebuild.
TONS OF EXTRA PARTS
The bad now:
CARBS NEED REBUILD
I have the rebuild kit.
The interior needs redone. It's been started but it needs finished
Will need a trailer to transport
On a current non op
Make me a offer!!
64powerglide
Re: 1963 CORVAIR FOR SALE ! Anderson Ca.
Unread post by 64powerglide » Thu Aug 10, 2017 6:07 am
GM didn't make a 66 102 HP!!!!!!!!
Unread post by bbodie52 » Thu Aug 10, 2017 7:59 am
I don't believe you will get much consideration without photographs. Exterior, interior, trunk, and engine compartment are needed. Also recommend VIN tag (left door jamb), Body Tag (engine compartment), and engine serial number (to the right of the alternator) close ups.
Is this a Corvair 500, 700, or 900 Monza?
4-door sedan, 2-door coupe, or convertible?
1966 engines were 95 hp, 110 hp, 140 hp and 180 hp Turbo.
GM 1 wire alternators are troublesome and provide no critical warning on the instrument panel if a fan belt flips or breaks.
What does "springs adjusted" mean?
:dontknow:
Unread post by azdave » Thu Aug 10, 2017 8:32 am
65 Corsa 140 4-speed
66 Corsa 455 Toro V8
65 Monza 455 Toro V8
65 Monza 4DR EJ20T w/5-speed
Return to “Vehicles For Sale”
