PICASSO RAMPSIDE STAKE POCKETS
Corvan, Rampside, Loadside, Greebrier
Vairamp
Post by Vairamp »
The bed rail stake pockets were “restored” on my ‘62 Rampside. They now have a certain “Picasso” look to them. Each pocket has its own dimensions. They’re not parallel either.
I’ve seen that stake metal is available for other pickups. Does anyone know if there’s a Chevy pickup model that’s compatible?
How do you get all the stake holes, at the top of the bed rails, to have the same dimensions? Maybe there’s a compatible donor pickup panel?
I’m trying to find the easiest most economical way to fix this without having to fabricate each pocket.
THANKS
joe moore
Re: PICASSO RAMPSIDE STAKE POCKETS
Post by joe moore »
I believe that the pockets are tapered.you can get a pocket plastic plug like I have on DOROTHY kind of hard to see but look close.
Sent from my SM-T580 using Corvair Forum mobile app
1962 rampside #3957
Vairamp
Post by Vairamp »
ALOHA
Thanks but that’s a photo of the air intake louvers.
I’m talking about the rectangular holes on top of the bed rails. The holes you’d put a tie down anchor in.
You could also put a piece of wood sticking out of the hole about 2ft. It would be a sort of fence post. I’d like to make a panel attached to that. It’d be used to support surf boards.
With those graphics on the side, I’m surprised you haven’t made a board rack. Colors of you Ramp looks great and it’s not even outside.
joe moore
Post by joe moore »
Ok here are some better pictures
1962 rampside #3957
Vairamp
Post by Vairamp »
That’s beautiful! Did you need to repair them?
Vairamp
Post by Vairamp »
Vairamp wrote:That’s beautiful! Did you need to repair them?
Mine were obviously done professionally haha.
These stake pockets are built with body filler at the top. If you were to grind out this filler they may or may not be damaged so that they are misshaped? I have not found this area to be particularly bad for damage or rust. The dimensions of the top, I think, are similar to other pickups of the time. If they sell little squares for other GM trucks they might work fine for replacement.
joe moore
Post by joe moore »
Ok the pockets on the rampside are the same dimensions as any Ford ranger box hole except the ramp seemed to be tapered. So the plastic cap just snaps in . Nice and clean.
1962 rampside #3957
Vairamp
Post by Vairamp »
Hi Joe, your pockets seem bigger than mine, even pre restoration. My Rampside is a ‘62. Maybe they’ve changed over the years?
joe moore
Post by joe moore »
No DOROTHY is a 62 also.
1962 rampside #3957
Vairamp
Post by Vairamp »
Is there a particular year or model that the Ranger bed rail fits better? How did you find that out?
joe moore
Post by joe moore »
Because I own a ranger truck.
1962 rampside #3957
Return to “FC's”
