New Corvair Owner - Hello!
RexJohnson
Re: New Corvair Owner - Hello!
Post by RexJohnson »
The emblem on the front fender is the "500" name plate.
RossettiJ
Post by RossettiJ »
RexJohnson wrote: Thu May 09, 2024 3:13 pm The emblem on the front fender is the "500" name plate.
Hey, mine doesn’t have those! What the heck?
John Rossetti
The Villages, FL
1965 Corvair 500 Coupe
fred bagnall
Post by fred bagnall »
The emblem on the fender is the 500 insignia emblem . The emblem is stock to that year and model. Keep it up you'll get there. Nice car :tu: :tu:
RossettiJ
Post by RossettiJ »
Please see my post under mechanical questions. I’m seeking help with starting the engine.
John Rossetti
The Villages, FL
Post by Frank DuVal »
Your 500 emblem was removed in the painting process. Now, if just paint, then the emblem holes would still be there, so there is either 1. welded up holes (extremely rare, as it is a lot of work for a person dedicated to clean lines only) 2. body filler because they didn't like the holes (and to use body filler the area had to be dented to hold the filler, holes alone cannot) or there was a dent (rust) there already. :td:
Time to use a magnet to see what's going on, or ignore and live without an emblem. Well, you might be able to cut the pins off and use emblem double sided tape...
:dogrun: :dogrun:
Return to “Introductions”
