Another Newbie
Another Newbie
Just putting a 2dr 66 together, can u still get parts?
thanks Bill
thanks Bill
Re: Another Newbie
You should be able to get 100% of parts you need although some parts are available only used . The largest vender is Clarks Corvair . https://ssl.corvair.com/user-cgi/main
For good used parts , best bet is probably Corvair Ranch
https://corvairranch.com/
Where are you located ? There may be a Corvair club near you that can give you more localized info on parts
- Bruins_Fan
Re: Another Newbie
Welcome to the Corvair Forum!
viewtopic.php?f=225&t=5030
Corvair Forum http://www.corvairforum.com/forum/viewt ... 225&t=6007
I would like to encourage you to expand on your initial post and tell us more about yourself, your Corvair interests, and your goals for your Corvair. Helping us to know more about you will help us to write comments to you that are tailored to your needs and experience. Detailed pictures of your Corvair — including the engine compartment — would possibly be useful. Knowing your location may also suggest possibilities in supporting your Corvair interests.
Re: Another Newbie
trying to load some photos with no luck. Is there a trick?
Re: Another Newbie
Are you using a computer?
The site on a mobile browser?
Or the app?
Or the app?
Re: Another Newbie
Where are you having issues? Did you find the place to add them under the "Full Editor & Preview" button?
Re: Another Newbie
Yes, I posted them in a new thread ...
Thanks
Thanks
Re: Another Newbie
Thks for the replys, I am in Sask. Canada, so parts will b a problem. I am going to try & load some pics,, it is a 66 2dr with a crown kit I think, just put a homemade 302 in it yesterday, have to hook everything up now
Re: Another Newbie
Corv8s are vairy cool
That 302 will be great for the car. Looks like you have a great project. Keep us posted on your progress.
First corvair in 1985
Have owned 4 corvairs since
65 Corsa coupe 180 turbo
66 Monza coupe 110 PG
66 Monza coupe 140 PG
Anchorage,AK
Anchorage,AK
Re: Another Newbie
If that's an old "short stroke" 302 it is a good fit for a Crown conversion. The later 302 (or was it a 307?) was a small bore long stroke engine that made more torque at lower RPM - not a good a fit as lots of torque at low RPM exceeds the Corvair transaxle capability.
You'll want to contact the V8 Corvair folks at https://www.v8registry.com/
A fellow in our club has a Crown V8 car. He's had it for a long time and destroyed numerous transaxles. He has learned a lot from others about making the car reliable. I hope you have $$$$ to spend. If so you'll have a rewarding and fun vehicle. A Crown V8 is NOT car to restore if you have a limited budget. Just my opinion.
Re: Another Newbie
Hello buddy, I'm also new here. Welcome from my side
Re: Another Newbie
Did not go in easy :( Thanks Q. Thanks 66 & 61, I didn't know about the trans axle problem till after I bought the car :(
